Old 11-25-2015, 10:05 PM   #1
ebaccm26
Need clarification on power steering swap
Going to be swapping power steering into my 69 c10 but after doing some reading I am a little confused about what parts I need. I am swapping to discs up front so I will be using 73-87 ball joints and tie rods. I would also like to use a 73-87 steering box for the quicker ratio. So do I need a pitman arm, idler arm, and center link for a 69 or for a 73-87?
ebaccm26 is offline   Reply With Quote
Old 11-25-2015, 11:00 PM   #2
Kennuck
Kennuck's Avatar
Re: Need clarification on power steering swap
I used a 1984 C10 box with the 72 P.S. Pitman arm all other parts are original 1970. Works great.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 11-25-2015, 11:20 PM   #3
ebaccm26
Alright I think I had the wrong pitman arm selected for the steering box and idler arm I was going to use, maybe it would have worked but I'll just go with what worked for you. Thanks for the help.
