6>8 Plugless........
![]() Join Date: Sep 2007
Air Pressure and 80lb Oil Pressure Gauge
I have a pretty nice air pressure and 80lb oil pressure gauge set with the rear tin. Air pressure gauge is really nice, but the oil pressure gauge has a little surface rust on the white paint of the gauge face. The flash makes it look worse than it is. $115 shipped OBO
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 04-24-2015 at 11:07 AM. |
![]() Join Date: May 2009
Re: Vacuum Gauge and 80lb Oil Pressure Gauge
Looks like you have an air pressure gauge there instead of a vacuum
You're right. I just noticed that. Thanks for the heads up.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 03-18-2015 at 08:58 PM. |
No problem, good luck on your sale.
$85 shipped.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Still have these. I tested them with 90psi shop air and both worked fine. The air pressure needle was in between 75 and 110. I took the 80lb oil pressure gauge up to 80 psi and the needle was at the last bar on the scale.
Pm sent
Joe 1968 K20 1970 K20 Semper Fi |
PM returned. Ryan.
I will take this for $85 shipped, as requested, and will be second in line for this.
Jaybatta is first in line. I will let you know if he decides not to pursue them. Thanks Ryan.
These are sold. Thanks Ryan.
