Old 11-26-2015, 11:32 PM   #5
sierragrande71
sierragrande71's Avatar
Re: project "C10 Fever" (68 factory black 396 swb)
Originally Posted by 68bowtie View Post
thanks! hey did i get that floor shift tilt column from you? i plan on installing it in this truck eventually...
the more i explore this truck the more i find. some good... and some bad...
some good ones... even though the PO swapped in a small block, the original high hump trans cover, 4-core radiator, engine stands, mounts, and radiator shroud are all still there.
Attachment 1462185
Attachment 1462186
Attachment 1462187
You sure did! Are you gonna put it in your truck? Anyways good looking truck man glad you found one!
sierragrande71 is offline   Reply With Quote
