dana 44 front hubs
are front dana 44 hubs being re-poped by anybody? can't seem to find any. 72-77? the disc mounts to the hub. might have to find a whole axle.
1961 chevy K10 my build is------------61K10 build |
#2 | |
Re: dana 44 front hubs
I can help you with your hub needs, if you are looking for good used ones. I have plenty. PM me and I will give you details if interested. Thank you, Thomas |
Currently Blazerless
Warn 9072 hubs are a good alternative to the Spicers, also a few other brands that make locking hubs for the old style external drive hub.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
thanks for the reply's guy's. found some used ones (hope their good) If not i will give you a pm DLTruck1973.
![]() Join Date: Nov 2014
Warn 20990 premium hubs
I didn't need the lock-outs as they are many avl. I needed the wheel hubs that go on the spindles. seems nobody has them. No more repo's?
Gotcha, might have to hit the bone yards, I've never had to replace those. Did I just jinx myself?
![]() Join Date: Aug 2008
Shouldn't all the 71-87 chevy 1/2 ton Dana 44 hubs be the same??? I'm not familiar with 3/4 and 1 ton stuff, but I would think you could get a used pair pretty easily and would be surprised if there isn't an aftermarket option.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...574033&alt=web
I found some Jason. those are big bearing and i need small bearing. I don't know if you can get a different bearing to make them work. anyway i found a set used.
putting disc brakes on my closed knuckle axle, and you need spindles and hubs from an open knuckle axle. should of just found a later axle for the parts. funny i always do things the hard way lol!
We've all been there, but we learn more that way!
![]() Join Date: Oct 2013
61K10,
Not real sure, but the Dana 44 ( Chevrolet version 1/2 ton) and Chevrolet 10 bolt (1/2 ton) may be the same up to 87', also could be Blazers and Subs up to 90' for these parts too. The 10 bolt stuff is likely more common. Recently purchased complete 83' 10 bolt with every thing including gear box, sway bar stuff for $150. Not sure for 61, however, for 64' axle all bolts in the same for 72 to 87' for Dana 44 and 10 bolt. Stock gear box linkage will need some modification. I have a modified linkage for 64' gear box some where. Photos available if needed. Just did an axle swap on 64'. Les |
#14 | |
#15 |
#16 | |
1. A 1963 K10 DANA front drivers side drum backing plate. (number on it is 310299-L) If I cannot find that I need to do the drum to disc conversion, and if that then... 2. Advice on the Master Cylinder, because the original Master Cylinder has one line going to the hydrolic clutch and the other going to all four drum brakes. Since I need to separate out the new front discs from the rear drums, and also the clutch, how do you do that? Any insights on any of that, or anywhere you could point me for either of those? I'm having a tough time finding the first, or info on the second. Thanks! Patrick |
| Bookmarks |
