Old 11-28-2015, 01:15 AM   #1
aod92
aod92's Avatar
Collapsing column shift linkage problem
I collapsed the column in my truck for more cab room. Now my problem is installing the shift linkage. I also did an ls swap with the Doug Thorley headers. It's really tight Becsuse of the headers. I bought the lokar shift linkage hoping that would help but it really doesn't. Any of you guys ran a set up like this? Your help is appreciated. Thank you
aod92 is offline   Reply With Quote
Old 11-28-2015, 01:55 AM   #2
'68 Newtricks
'68 Newtricks's Avatar
Re: Collapsing column shift linkage problem
Put a bend in the rod. I just did the same thing except I'm running TBSS manifolds. Collapsed the column about 3", ran Lokar to a 4L65, seems to shift great. I only put one bend in it down near the trans.
I think Lokar makes a kit that uses your stock shift set up but turns it into a cable. Something like that. Might be worth a look.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 11-28-2015, 04:02 AM   #3
aod92
aod92's Avatar
Do you have any pics of what you did?
Old 11-28-2015, 11:34 AM   #4
'68 Newtricks
I have the same thing you do but with different exhaust. I can see how yours are completely in the way. Not sure if a couple bends will help, you'd have to line it up. Here is the alternative I was talking about
http://www.lokar.com/product-pgs/col...shiftlink.html
'68 C10 SWB
'85 K30 Blazer
Old 11-28-2015, 11:49 AM   #5
aod92
aod92's Avatar
That is something I might have to go with. I'm gonna try bending the rod first and go from there. Thank you!
Old 11-28-2015, 12:06 PM   #6
chiefcfd
chiefcfd's Avatar
You could fab up an extension to move the heim joint closer to the fire wall. an inch or so looks like it would clear for you. The two 90 degree bends like the RV column has in reverse would do it.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 11-28-2015, 12:18 PM   #7
aod92
aod92's Avatar
Could you tell me a bit more about this? I'm not sure what you mean.
Old 11-28-2015, 12:32 PM   #8
chiefcfd
chiefcfd's Avatar
Looks like where the heim joint is mounted to the column is too far forward. If you made a bracket that would move that location towards the firewall it would clear the header and work better. Here is a pic of the RV column and the bends it has. You would need the bends in reverse as they move the point towards the radiator support. I hope this makes sense.
http://67-72chevytrucks.com/vboard/s...d.php?t=551454
Old 11-28-2015, 12:36 PM   #9
aod92
aod92's Avatar
Ok, I see now. That's something that might work too. Thank you
Old 11-28-2015, 04:35 PM   #10
outlaw 3454
outlaw 3454's Avatar
longer bolt and a spacer is all you need
outlaw 3454 is offline   Reply With Quote
