Old 11-28-2015, 09:26 AM   #1
firemandave
wheel offset stock rearend
Hey guys, wondering about backspacing/offset for a 20x12 wheel on a stock 67 rear end width? Any help would be much appreciated. Would like the tire to be really close to the edge. I've trimmed the inner 45 degree lip already.Any photos? Thx,David
firemandave is offline   Reply With Quote
Old 11-28-2015, 09:34 AM   #2
Heavymetl
Re: wheel offset stock rearend
That's a huge wheel, 20x12.
Always best to measure.
FWIW, on my 15x8 wheels I'm just running the standard 50/50 setup, so the 4 inches "out" from the flange but my tire close to the stepside fender.
Depending on overall tire height, I'd need to run something like an 8" backspace and a minitub on my truck to fit a 20x12!
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 11-28-2015, 02:22 PM   #3
firemandave
Im planning on cutting the bed to fit. just don't want to narrow my axle.trying to squeeze as much as I can under it. Thanks for the reply
Old 11-28-2015, 09:01 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
Are you lowering the truck? How much did you trim the lip? If you're running a stock width 67 rear, 7"-8" backspace is what you'll need, depending on how much you cut out. 7" will put the tire right at the fender lip on the inside, 8" will give you a little clearance, as Heavymetl posted above. I'm running 19x12's on 6" backspace with a narrowed rearend (1" on each side)and I cut about 1/2 of the fender lip out and my tire is right at the edge of the inner fender lip with a 7.5" drop. DO NOT take these measurements as the gospel - your results WILL vary, so make sure you measure over and over again with the bed on exactly how you'll run it with the 12" wide wheels. I see way too many people on here asking for measurements of what everyone else did, but the only way to know for sure is to check. A 20x12 is probably a custom order and usually too expensive to do over if you don't get it right.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-01-2015, 08:16 AM   #5
firemandave
Thanks,only lowering 2.5/4 inch . Looking at photos I may end up with more drop! Have a ford 9inch so there will be tons of measuring before wheel purchase. Thanks for the advice/pics, great looking truck.
