Old 11-30-2015, 09:43 PM   #1
masterlock
masterlock's Avatar
Loose steering to the right
So I am trying to work out my steering issues on my lifted 78 K20. Changed out the pitman arm and steering arm to fix the geometry and replaced the drag link, replaced the tie rod ends and tightened up the gear box adjustment screw. the steering is better than it was but it is very loose to the right???
If I am driving down the road and swerve left it is very responsive if I swerve right it is sloppy. Also if I hard brake at speed i drift right.
So I am going to replace the Rag joint, maybe that will help. After that Im not sure where to go next. Ball Joints, Wheel bearings? Also I have been holding off on an alignment until I change out everything that needs changing but if that might help then I might do that.
Any suggestions on my next step?
masterlock is offline   Reply With Quote
Old 11-30-2015, 10:35 PM   #2
72 k10
Re: Loose steering to the right
sounds like the steering box is bad I don't like to adjust the box like that I have seen em lock to one side during a turn. a new box is under 400.00 and really make a big deference. ball joints are also commonly worn out
72 k10 is offline   Reply With Quote
Old 11-30-2015, 10:41 PM   #3
masterlock
masterlock's Avatar
Yeah I am trying to change everything out before I get to the power steering box, would loose steering in one direction be a common symptom of a bad gearbox?
Old 11-30-2015, 10:49 PM   #4
11555wally
I had my steering gear replaced on my 86 because it was a little sloppy. The first one they put on the truck pulled to the right and it was harder to steer to the left. They realized that the replacement gear was the problem so they put on another, same problem. They put on a third one from a different remanufacturer and it steers great now. Could be your gear and if you replace it make sure it is a good one.
11555wally is offline   Reply With Quote
Old 11-30-2015, 11:11 PM   #5
masterlock
masterlock's Avatar
do you remember who made yours?
Old 12-01-2015, 12:46 AM   #6
72 k10
saw a post on the forum a guy is getting them off of e bay for under 400.00 I think the brand was ccp he had done several and was very happy I believe these where new units not rebuilt.
Old 12-01-2015, 12:48 AM   #7
hatzie
Moderator
hatzie's Avatar
New rag joint or a Jeep XJ steering shaft with universals.
There are several Youtube howto videos on the XJ shaft mod.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-01-2015, 08:35 AM   #8
11555wally
I don't know who remanufactured mine. The garage that did the work uses a distributer for their parts and I know after the 2nd bad one they told the distributer not to give them one from the same remanufacturer. The garage took a beating on the deal because they only charged me for tthe first replacement. I think I would spend the money to buy a new one. If I had done my own work I don't think things would have turned out as well.
