Old 12-02-2015, 09:31 AM   #1
68Timber
I know the pieces fit
68Timber's Avatar
Re: Sarge's rattle-can rebuild
I just went through the CUCV melted fuse issue where you lose all lights and horn. I'm sure you're familiar with that one. I used the Steel Soldiers fix, including LMC's heavy duty headlight wiring kit. I already have Sylvania Silverstar headlights on the truck but adding this harness made the real difference. I'm sure his is better quality, the the $25 version from LMC made much more difference than I thought it would. You don't know how much you're leaving on the table until you wire one up.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
