are C20 C10 C30 cabs the same size?
Wondering... If I decided to find another cab for my son's truck.
![]() Join Date: Jan 2011
Re: are C20 C10 C30 cabs the same size?
I think so. Are you looking to replace the entire cab or just getting one for parts. This comes up a lot on cab swaps. Can be lots of issues when swapping complete cabs with the vin number on the cab and chassis not matching.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Mar 2013
They are swapable. But as said you'll have Vin issues.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
60-66 Nut
Yes the cabs are all interchangeable. I would check with your local DMV to see what is needed to make a cab swap legal.
We will check.
60-63 have different doors than 64-66. If you are going to use the doors that are all ready on the replacement cab you'll be fine but if your switching doors you might run into problems.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
We are going to use the doors too. Tonight we are going to go an purchase a 1966 C30 dually... No bed on it.
292 with SM420. Pretty cool! |
