Intake manifolds for torque
I'm looking to build my high compression 6.0 for max torque. I'm guessing the stock truck intakes work best for making torque in the lower RPM range. The car intakes and aftermarket intakes seem like they are designed for higher RPM horsepower. Anyone recommend an intake that is best for low RPM torque.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9 Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Re: Intake manifolds for torque
Hot rod magazine recently published a test of about 20 different intakes, if I remember the TBSS was the best when compared to the other stockers. Check their site to be sure.
65Gregg Blue long bed White TBSS 61 Impala The two most important days in your life are the day you are born and the day you find out why. Mark Twain |
"I'm guessing the stock truck intakes work best for making torque in the lower RPM range."
You seem to have answered your own question. |
meowMEOWmeowMEOW
The l92 intakes are better, but that will require square port heads. On the cathedral port stuff; truck will be best under around 4k rpm for torque. The LS6 intake is a decent option, worth around 20hp on the top end.
Keep in mind, what intake works best will be a function of the overall flow characteristics of your motor. Find the bottleneck and work from there. (I.e. no reason to spend $$$ for a FAST manifold and a 102mm tb on stock heads and a mild cam)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I like the looks of the LS6 intake. What is the difference between the LS1 intake and the LS6 intake?
#6 | |
Boosted Member
The internal shape is different as well...higher flowing. Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by ETsC10; 12-03-2015 at 07:17 PM. Reason: Non-supporting member offering to sell. |
Great article, thanks for the link. It looks the the two truck intakes would be best for me. The only issue is they are ugly. Dorman makes a replacement trailblazer intake that could be cleaned up to look as good as the LS6 visually, yet make the big torque numbers.
Part number 615-183
| Bookmarks |
