12-03-2015, 01:03 PM | #26 |
Re: Air ride conundrum...
Is there a particular kind of compressor thats better than others?
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
12-03-2015, 02:17 PM | #27 |
Frequent Flyer
I am a fan of Viair compressors.
12-03-2015, 02:49 PM | #28 |
While F/R set-ups are cheaper, they will allow more lean vs 4 corner control.
My dually requires different psi on the LF vs RF to achieve the same ride height too (something to consider as well). For a dually, definitely go w/the largest volume tank you can fit & utilize 2 comps (or an engine driven set-up). There's alot more weight to lift vs a 1/2 ton SWB w/a sbc.
12-03-2015, 02:57 PM | #29 | |
12-03-2015, 03:01 PM | #30 | |
12-03-2015, 03:07 PM | #31 |
Im pretty sure Im going with a 2-link setup but I have to do some measuring to see if what i have planned in my head is going to work. I wanna put bags on the rear of the 2-link bars but im not sure if Ill have the space requirements. May have to put bags on inside of the frame above the axle in which case id have more room.
12-03-2015, 03:15 PM | #32 | |
It might be something that's not noticed.... or it could be. I'm guessing it's subjective. My 4-bar utilizes sleeve style 3500# bags directly behind the axle where the leafs were positioned. Decent ride for sure vs the HD OE leaf pack.
12-03-2015, 03:34 PM | #33 | |
Found this but pretty sure its too tall. http://www.kmwperformance.com/product/CT-BAGA-M14156-01
12-03-2015, 05:23 PM | #34 |
That seems pretty large capacity wise. Mine are similar but w/a 3500# rating & smaller in size.
12-03-2015, 05:33 PM | #35 |
LOL yeah those are a little overkill..
12-03-2015, 05:52 PM | #36 |
For reference, I'm running about 45psi for 28" @ the rear wheel fender lip (@ C/L of opening w/31.7" tall tires) for ride height. I run between 27-28" typically.
12-04-2015, 08:11 AM | #37 |
What size and what kind of tanks and pumps are you running? I was looking at your setup and it looks nice!!
12-04-2015, 10:01 AM | #38 |
I run the larger Thomas compressors from Ride Tech & had 3gal aluminum tanks built.
12-04-2015, 10:30 AM | #39 |
I Think I have room for 2 8 gallon tanks. You think thats overkill? I was looking at the viair 444c compressors. I would run 2 of them. I would like to be able to have an auxiliary air port for air tools in case i need to change a tire or something. After all it is going to be a working truck.
