Hello all! Hopefully someone can instruct me on how the upper tailgate trim fits together. does the center trim piece fit on top of both outer trim pieces or are they supposed to have the center trim piece inserted into the ends where they meet? I can't find a really clear picture showing the orientation of how they fit together.
Thanks! Ben Smith ![]() |
Re: upper tail gate trim
Can't answer all your questions but I do know to make sure you open the tailgate and remove the nuts that fasten the very outer ends of the upper trim (on the inner side of the tailgate).
I believe that the rest of the fasteners are best removed using one of those nylon trim remover tools and a very small pick. You lift the trim slightly and slide the point of the pick behind the trim to catch the end if the spring wire and allow it to unhook it from the well in the trim. Once you see one you can do the rest... |
![]() Join Date: Dec 2013
center piece goes on first and the long ends go over the center , and usally it is the self locking jaw type molding clips
I seen another post today that said the center piece goes on top of the two outer pieces, can someone please show me a good photo of how it looks installed?
Thanks! Ben |
![]() Join Date: Aug 2007
Center piece goes on first and the outer two overlap it
Scotts72C10 |
Picture 2
Scotts72C10 |
here is a picture of the center piece, that a other board member has for sale , you can see they go on the outside , see the oxidation ect, and looking at back you can see , they cant fit
Thanks Guy's! That clears up a lot of confusion I had about how it all fits.....
Have a great weekend!!! Ben ![]() |
If it's counterpart, it won't fit worth a darn. I threw mine in the trash can it fit so poorly. I hate counterpart.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
Yeah, that's what I'm afraid of......
Ben |
