Old 11-24-2015, 09:35 AM   #751
Iceburgh
Iceburgh's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Originally Posted by FarmerSid View Post
I will be getting my hooker headers tomorrow so I will post a picture to compare the two.
curious to see how you feel about these and also the cost.
I am happy with the fit of my headmen but they were not cheap.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 11-24-2015, 11:46 AM   #752
Advanced Design
Advanced Design's Avatar
Will do Jim. I cheated ...took the tire and the truck to dealership to fix. Glass guy is here replacing windshield. Prioritizing my time to be able to do some burb work. Will get back on it!
Sid, looking forward to seeing how your headers fit. I will throw these Camaro manifolds on to see how they look.
Iceburgh, Did you have to trim the frame just a bit? Also, did you get your electronics on your LS worked out?
Back to the shop for me....
Advanced Design is offline   Reply With Quote
Old 11-24-2015, 01:53 PM   #753
Advanced Design
2010 Camaro manifold on the left side needs this much angle to almost clear the frame.
Old 11-24-2015, 01:55 PM   #754
Advanced Design
And with the angle, the manifold hits the block. So, I'm going to go with some headers and use these manifolds on a different project.
Old 11-24-2015, 03:03 PM   #755
RockinKees
RockinKees's Avatar
I'm glad I'm not the only one who has had problems with headers...
It seems like we all do!
Hope you find the right ones the first time
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-24-2015, 04:58 PM   #756
Advanced Design
Thanks Kees, me too. The broke vortex continues. The windshield for the dd was made wrong so he is coming back Monday with another one. Grasshopper and Gator each had one flat tire. Battery in 56 was marginal starting. Tested good recharge so we will see. Just drove it 30 miles though....
Never give up, never surrender.........
Old 11-24-2015, 05:24 PM   #757
Iceburgh
Iceburgh's Avatar
[QUOTE=Advanced Design;7387211]Will do Jim. I cheated ...took the tire and the truck to dealership to fix. Glass guy is here replacing windshield. Prioritizing my time to be able to do some burb work. Will get back on it!
QUOTE]
Yes slightly...they fit but with the motor torque I wanted 1/4"
No not yet maybe on Turkey day. Gives me something to do when the rest of the family is there.
Been working on the '56....LOTS of work to do there
1953 suburban build
Old 11-25-2015, 12:53 PM   #758
youngrodder
youngrodder's Avatar
I'm curious if my Camaro manifolds will work with the PB set up. I remember one of the changes they made that delayed things was a change to allow a more flexibility on header selection. Fingers crossed that I can use the stock manifolds. I wont know for quite a bit.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-06-2015, 09:51 PM   #759
Advanced Design
Marc
Will be following along Marc to see how it works out.
Saturday morning planned the day in the shop, then wife reminded me we had a funeral to go to. Leaving at 9. OK, lunch in town, back home at 1:30. Sit down in recliner for just a minute before hitting the shop. Mistake...two hours later I headed for the shop. Ugh.
Not much done again...removed a broken bolt from the radiator support. Need to mount it up to see if I will have room for the accessory drive. Don't want to move the engine back unless necessary. Can't really tell yet. This is the truck water pump. I will put the inners on, add the accessories, mock up or buy the radiator assembly and then decide.
Old 12-06-2015, 10:34 PM   #760
youngrodder
Well that worked pretty slick. Any progress is good progress. My Sundays are usually really good days for me to spend in the garage. Only problem was I was very FESTIVE at a holiday party last night and just felt like holding down the couch today......
Keep at it
Marc
Old 12-07-2015, 12:12 AM   #761
Advanced Design
Keep at it
Marc
Thanks Marc. The same trick will work on exhaust bolts broken off in the aluminum head as long as you can get welding wire to it. Hey, best part about festive flu is you know it gets better as the day goes by.
Iceburgh, it would be great if you could start a build thread on the 56 you are working on.
Old 12-07-2015, 08:32 AM   #762
lower50's
lower50's's Avatar
Another way to get a bolt out is to place a bigger nut on the head and weld up the center. Lookin good!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-07-2015, 09:04 AM   #763
youngrodder
56??? Is Jim holding out on us?
Marc
Old 12-08-2015, 12:00 AM   #764
Advanced Design
Marc
Must be. He mentioned doing a lot of work on a 56.
Old 12-13-2015, 05:06 PM   #765
Advanced Design
Saturday was fun.
Old 12-13-2015, 05:09 PM   #766
Advanced Design
And C6 manifolds won't work. They are pretty tight on the left side and hit the frame on the right side.
Old 12-13-2015, 10:57 PM   #767
youngrodder
So the search continues??
Marc
Old 12-13-2015, 11:28 PM   #768
Advanced Design
Lower, good idea too. Way better than drilling and trying an easy out!
Old 12-13-2015, 11:30 PM   #769
Advanced Design
Marc
Yep, a friend had these laying around. So either the headers Iceburgh used or the Hooker ones Sid used will fit ....I hope.
Old 12-14-2015, 09:06 AM   #770
FarmerSid
FarmerSid's Avatar
Don't know how the C6 compare to the Camaro manifolds but the flange is higher and closer to the block with the Hookers. Got anymore pics of the flange area on both sides?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 12-14-2015, 11:08 AM   #771
reaper71
reaper71's Avatar
Hey Doug here is the set of headers I used on John's Dodge truck.
They are from Speedway #9300114 $200.00 comes with O2 bung, gaskets and the flanges witch you can turn in several positions.
Pic #2. installed on johns.
(By using Hugger Headers You will have to move motor mounts forward!)
Mark...
reaper71 is offline   Reply With Quote
Old 12-14-2015, 08:45 PM   #772
Advanced Design
Sid, here is one more pic on the left side. The right side contacts the frame (it won't even bolt on) so I need to compare the manifolds as the right side one must extend outward some....or my engine isn't centered and level.
Mark, Thanks for the lead on the headers you used on John's Dodge. I'll look them over to see if they will work. Like you mentioned, the engine mounts would probably need to be moved forward.
Old 12-14-2015, 11:58 PM   #773
99 to Life
99 to Life's Avatar
I found these on Ebay and since Im a huge fan of stainless and have bought ebay headers bf, they are worth every chineese cent. I was skeptical on trying them cause I have nothing moched up yet, then I stumbled upon a guys build on here, but he hasn't responded back to my question (I don't think he gets on here much) or maybe I missed it and I can't recall his build thread. But... I did poach a pic from his thread when I saw it. Cause I recognized the headers. For me I think this is the route I'll try and take, so I'd need to order them, then do engine mounts and try and find a happy medium.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-15-2015, 09:01 AM   #774
Advanced Design
Thanks 99. Those look good and I appreciate the idea.
Old 12-15-2015, 09:13 AM   #775
FarmerSid
FarmerSid's Avatar
I think your engine is a little lower between the frame rails than mine but here's a few of mine with the Hookers on. Hard to see through pictures but the right side down pipe is about an inch from the frame rail. You can see the flange is a two bolt and is higher than the Camaro manifolds.Gives you something to think about.
C4 IFS & D44 IRS
5.3 HO L33
