![]() ![]() Join Date: Feb 2009
Vacuum Reservoirs - much go wrong with these, test methods?
Just polished this one up. 3M plastic cleaner and "lens" protector worked rather well, though I see by this image, I missed the arms some, especially the edges. Still not bad for being on the truck 45 years.
For 20 plus years, the ports were left open and unprotected. Not much exposure to elements. Does much go wrong with these units? Also, any recommendations how to test these and other vacuum type valves? Thank you for any response. ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-09-2015 at 01:17 AM. |
Re: Vacuum Reservoirs - much go wrong with these, test methods?
Pump them up with a vacuum pump and see if it holds if it does then it is good if not it is bad.
Just ordered a kit, thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-06-2015 at 09:07 PM. |
If not too late - IMO the metal version of the vacuum pump (assuming you got the MityVac) is all the way better...
I learned the hard way and bought the plastic one first... then a few months later the metal one. Lots of uses for this tool and its fittings so you won't regret it.. (for example testing your distributor vac advance to see when it starts moving and how far and at what Hg (or is it Mg).. Inches of Mercury.. |
#5 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
