Old 11-24-2015, 11:47 PM   #1
sp690
Lsx direct bolt on turbo kit
So I recently started working on my truck. I was just going to build my 5.3 with a nice cam and nice sounding exhaust but plans change when you start googling. And now IM interested in doing a turbo build. I know a lot of guys are just making their own manifolds and welding most of the piping since you really can't get a direct bolt on kit since there are tons of different setups you can make. I don't have a welder and im by no means a fabricator. (Sorry for the long story) I found a direct bolt on kit for a ls1 camaro and I wounder if anybody has tried using them, the turbo is mounted in the lower front part of the engine and all the piping is tucked in around the engine pretty tightly. I'm using dirty dingos sliding engine mounts so I can move it rearward some. I can't paste the link but it's on eBay ( yes I read all the topics about the "ebay" kits) just search ls1 turbo kit. I know I will probably have to pay to get some things fitted but I'm trying to not pay too much, thanks again for any help
sp690 is offline   Reply With Quote
Old 11-25-2015, 12:18 AM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Lsx direct bolt on turbo kit
Probably going to be hard to find a direct "bolt in" kit that is going to be headache free. What kind of truck is it going in?
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 11-25-2015, 12:27 AM   #3
sp690
I'm working on a 68 c-10. My problem is that I don't have my front clip on so I'm really not to sure how much room I'll have between the engine and the radiator. I was thinking that with an ls1 camaro turbo kit I would have to make the least modifications to the piping.
Old 11-25-2015, 12:36 AM   #4
aknovaman
Look at the Huron speed truck kits. Camaro kits will hit the truck power steering pump and bracket. We did a 85 Chevy truck using the Camaro kit and it would have been easier to build one from scratch than modify the Camaro kit.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 11-25-2015, 12:50 AM   #5
sp690
I forgot to mention I have 5.3 but I'll be using all the ls1 accesories.
Old 11-25-2015, 02:55 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The answer is no. There is no bolt on kit that will work. If you want bolt on no-worry performance, buy a P1sc or D1sc. It'll fit right, be easy to have a tuner setup for you, and won't require any real fab (depending what you choose for cooling).
Even with a bolt-on kit from a different car, you'll end up needing to make changes. Things like blowoff and wastegate locations and tubing is different on every truck, even two virtually identical '68s with a 5.3 will wind up with variations of the same setup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-25-2015, 03:46 AM   #7
tinydb84
tinydb84's Avatar
Here is a thread that discussed it a bit: http://67-72chevytrucks.com/vboard/s...d.php?t=653977
Turbos can be done fairly cheap if you can weld/fab but if you cant it will be pretty costly. Br3w suggestion makes a lot of sense if you cant fab (the costs will be kinda similar). Remember you will need to factor in the costs of upgrading your fuel system, redoing your tune, etc.
David
Instagram: myfabguy
Old 11-25-2015, 07:21 PM   #8
sp690
I think your right, best bet for me would be to go with a sc. Or just go with a big cam.
Old 11-25-2015, 07:27 PM   #9
aknovaman
There is plenty of room in a 68 for a turbo. The eBay turbo Camaro kit is what we used. The only part was the drivers manifold issue as I stated above.
FMCDH GBU and GBA
Old 11-25-2015, 07:30 PM   #10
sp690
Yea but my deal is I don't have the tools or probably skills to fab it all and if I pay for someone to fab then it will get real expensive real quick
Old 11-25-2015, 07:32 PM   #11
aknovaman
Understood. Find some street rod car buddies they are excellent fab guys and usually help each other out for cheap.
FMCDH GBU and GBA
Old 11-30-2015, 08:17 PM   #12
Crash'd Artwerks
Too bad you're south of Ft. Worth. I'm in McKinney and could help fab it up if you were closer.
Crash'd Artwerks is offline   Reply With Quote
Old 12-07-2015, 04:19 PM   #13
Pillow
Pillow's Avatar
Get that suspension right first. These old girls can get squirrelly under NA power much less FI power!
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
Old 12-07-2015, 10:27 PM   #14
Jon01
Jon01's Avatar
Cheap does not go with any kind of forced induction build. Especially if you can't fabricate.
Build a nasty h/c motor and enjoy it. They work just fine.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 12-07-2015, 10:31 PM   #15
aknovaman
Know josey with the 280z or his buddy with the red rx7? Both are turbo lsx and very affordable. You can build a turbo setup on the cheap for close to the heads and cam setup and get an easy 500hp or more, Plus its more streetable. Cnc heads are expensive.
FMCDH GBU and GBA
Old 12-07-2015, 10:41 PM   #16
Jon01
Jon01's Avatar
Know of them, don't know either of them directly but from what I've heard they built their own kits...something this guy admits he can't do.
You won't find someone to fab a functional system up for 2k which is about what he'd have in a cam and set of CNC'd 243/799 heads if bought right.
Fab work is the tip of the iceberg to do it right - big fuel system will set you back a grand + (really big for corn), good converter another 12-1500, good trans that will take it over and over, 4-5k, good diff before you blow up stock posi is another 500, better get axles while you're at it, there's another 3-400. Good driveshaft another 3-400 on the low end.
I'm at 8k and haven't even put a turbo in there.
Also going to want decent suspension, there's another 3-4k.
Sure, you can do it cheaper with a stock 80e and HD2 but it'll be broke/blown up/on borrowed time and likely to break at the least opportune time.
Old 12-07-2015, 10:44 PM   #17
aknovaman
I believe you are over exagerating on your prices but thats ok. You dont need a 1200 dollar fuel system for 500hp turbo setup. My buddy bought a turbo 2002 silverado used for less than 10k.
To each their own.
FMCDH GBU and GBA
Old 12-07-2015, 10:52 PM   #18
tinydb84
tinydb84's Avatar
You dont even need to know how to fab! Look at the sloppy mechanics stuff.You can get away with a Walbro 400 for 500whp. Get a junk yard Impala rear when/if you blow yours.
I think heads and cam are a great idea and you can still go turbo later if you plan your cam right.
You have tons of options. Just spend time here and the LS1tech forums before you make any decisions.
David
Instagram: myfabguy
Old 12-07-2015, 10:54 PM   #19
Jon01
Jon01's Avatar
Hell, my injectors were $900.
Like I said, you can do it cheaper but it's cobbled IMO. Do it right, spend the $ so when you want to turn it up you can.
500hp? Why bother putting a turbo on it? Cam and spray and roll out.
Old 12-08-2015, 03:04 PM   #20
slotard
http://www.roadandtrack.com/car-cult...hevy-colorado/ it can...
he posts on another forum I'm on, he's with sloppymechanics that someone else mentioned
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-08-2015, 03:07 PM   #21
aknovaman
He uses good parts but horrible fab quality skills used. Dangerous but screaming fast and powerful
FMCDH GBU and GBA
Old 12-08-2015, 04:35 PM   #22
slotard
I was under the impression that he tends to use cheap parts, and the fab quality on this one doesn't seem to be quite as bad as some of the others.
1973 C20, 350/350
Old 12-08-2015, 04:38 PM   #23
aknovaman
See his trans crossmember? Scarey weak welds. He did not fab the hot sude. The ones he fab up welds are terrible. He is even proud of it.
FMCDH GBU and GBA
Old 12-08-2015, 06:30 PM   #24
tinydb84
tinydb84's Avatar
He does use cheap parts. He has links to all of them in a long thread on ls1tech.
Running a lot of e85? You can get 80lbs injectors for $300. I don't see a problem doing some fab work for a reliable 500lbs that is always on.
I agree with you on that. I would be embarrassed to run any of his fab work on my truck but he made it clear you can go really fast for cheap.
Side note-Anyone see the thread on weldingweb where the guy buys thousands in tools and spends two years learning to tig weld to build his own turbo hotside? I will try to find the link when I have some more time.
David
Instagram: myfabguy
Old 12-08-2015, 06:36 PM   #25
aknovaman
Hey, that sounds like my tool buying process / philosophy. ;-)
FMCDH GBU and GBA
