6>8 Plugless........
![]() Join Date: Sep 2007
Re: 1977 Silverado Crew Cab.
94-02 2500 and 3500 4x4 Dodges have a 4" cast block in the rear of them as well. The only problem you might run into might be the ford and dodge springs are wider than the older chevy ones. I almost went with a 241 for my 76. I still might if I can find a core at a decent price.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
I know the pieces fit
I like the 241 idea. The TH400, adapter, and 205 can be flipped for good coin and the 241 is more than adequate for normal use.
Following closely! You are doing to yours what I want to do to my 88 GMC crew! I also have a donor 1 ton w/ the dana 60 I need to swap over.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
#4 | ||||
Second Chance Program
Yep! I'm following yours too! Sadly the 60 swap won't start for a good couple months as I am remodeling my kitchen starting right after Christmas... Yippie!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
Well then! Mine will be starting not in the far distant future I just have a lot going on right now with a couple of fbody's. I want to have the front end stripped from the 4x4 before the end of the year and the 350 tbi in the 88 needs a head gasket. Still trying to decide where I plan to get my 4x4 swap parts from.
I would get the spring mounts from diy4x4 and the cross member from either totally naked auto or off-road design. However , I'm thinking I'll make my own front mounts and buy the shackle mounts from diy4x4 and the crossmemeber probably from TNA.
Camaro Club
I'm not sure what those crossmembers or spring mounts cost but I was able to use all factory parts on my swap. The factory 4x4 engine crossmember only took a little bit of tweeking to fit in the 2wd frame. The frames are very similar but not exactly the same. I found that the 2wd frame was around 3/8 of an inch shorter in height at the engine crossmember area.
