Can't catch a break!
Okay so 3 years ago all my wiring under the hood melted and my sagnaw 3 speed went out
Well 3 weeks ago I got it back on the road with a fresh rebuilt transmission. Well today I was in 2nd gear and it started to shimmy HARD. I stoped at a stop sign, took off in first and about 3 feet I hear a real loud clang,clang,clang. That's all she wrote. Tranny main gear is busted. What 4 speed can I put back in it without changeing my bell hauseng. And my drive shaft has that round peace that slides in the tranny. Who do I change that. Thank you everyone |
![]() Join Date: Mar 2013
Re: Can't catch a break!
Boy if you were in my town I'd have you stop by and we'd throw in a SM420. I have all the parts need(I think). lol Tranny is 50 years old but shifted nicely. Course its been over 1 year now sitting. Hope ya get it fixed soon!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
1961 crewcab
any 60-66 truck 4 speed will bolt up, the 4 speed driveshaft is longer in between the trans and carrier bearing than the 3 speed. depending on what you currently have you will need to source the driveshaft out of the donor truck as well, you also might need a high hump (with the firewall section) and high hump floor mat.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
If it was a fresh built transmission would it be under warranty? Do you know why it failed?
1965 C30 Dually, 230ci/SM420 4SPD/MS/MDB |
We get mixed up on these 3 speeds,but if you have a Saginaw sycroed 1st gear ,which is not what came in the trk you can hang a Saginaw 4 speed in it's place. If you have a Muncie 3 sp. non sycroed 1st gear you can put a car 4 speed in also but the drive line will probably have to be shortened
![]() Join Date: Apr 2009
I have a 1964 3 Speed you can have Free just pay shipping
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Thanks for the offer tj's chevy! And they said the tranny MIGHT be under warranty. They took 2 used ones I could come up with and made one work. He said if it's due to workmanship it's on them if it's a gear I'm SOL.
Okay! Found the break I've long needed! It's the u joints!!! Not the tranny. Shell be back on the road by Sunday. Thanks everyone! As far as the 64 3 speed I'd like to have it if it's a long tail and it works. Just get me a quote please. Durant ok 74702.
If you have a Saginaw sycroed 1st gear ,which is not what came in the trk you can hang a Saginaw 4 speed in it's place. If you have a Muncie 3 sp. non sycroed 1st gear you can put a car 4 speed in also but the drive line will probably have to be shortened.???
Solitaire |
My transmission is ssa non synchro.
Chevy addict
Make sure you have the U joints seated in the yokes, install all new joints, cheap insurance you have eliminated a possible break down in the future.
