12-09-2015, 08:01 PM | #1 |
1966 250 dipstick correct??
I have a 66 c10 with the original 250 six cylinder and according to the dipstick it holds 4 quarts of oil up to the full mark. I read it is supposed to hold 5 quarts. I am using the larger filter...Does this appear to be the original dipstick? or any other suggestion?
12-09-2015, 08:06 PM | #2 |
Re: 1966 250 dipstick correct??
My 70 with a 250 6 was 5 quarts with filter,4 without filter. I can't double check since I don't have the truck, but that does look like the dip stick for the GM 6.
12-09-2015, 09:10 PM | #3 |
I am showing full with a new wix 51060 and 4 quarts of oil. Could I have a quart of sludge in the pan?
12-09-2015, 09:34 PM | #4 |
My 292 also takes 5 quarts with a filter.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
12-09-2015, 09:49 PM | #5 |
Have you run it yet?
12-09-2015, 11:12 PM | #6 |
Yes have run it... seems ok but want to have the correct amount of oil..
12-10-2015, 09:39 AM | #7 |
any other ideas?
12-10-2015, 11:09 AM | #8 |
A) make sure the dip stick tube in the block is correct
B) do you have a friend that has a 250 ? borrow his dip stick and see if their is a difference.
If you don't like this pound sand ..... |
12-10-2015, 11:11 AM | #9 |
Just from what I can see , that dipstick looks to be the pre 1963 design with the , for lack of a better term, the loose washer style , they used these on early 235s and v8s. Then they changed to the style with the sleeve that fits over the dipstick tube. Is there a part number stamped in the dipstick down at the bottom ? Looks to be something there? I can track that number. I would put the 5th quart in it and mark the level after its been run. Never heard of a 4 quart system.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
12-10-2015, 07:25 PM | #10 |
Since it was mentioned, I looked in my old photos and this is the only views of the dipstick on my 70's 250 that I had.
Maybe they will help, but it may be as said above that was one from the older style 6.
12-11-2015, 10:55 AM | #11 |
Thanks for your help guys. It has no numbers on it but has a M stamped close to the word FULL. I have a friend with a 250, will see what his has. Thanks again.
