Old 12-11-2015, 01:16 PM   #1
slotard
Van LQ4/4L80E
I found a 2005 box van, SRW, 8 lug that was crashed and is being parted out. 131k on it. He says it's the 6.0, and I believe it should be a 4L80E. I can get engine/tranny/accessories/wiring for a good price (for here), $1300.
Is there any reason not to go with a van engine/tranny?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-11-2015, 01:40 PM   #2
foamypirate
foamypirate's Avatar
Re: Van LQ4/4L80E
No reason at all not to use that over a truck LQ4. $1300 is a deal for an LQ4/4L80E. I paid $1500 alone for my LQ9 (granted, the LQ9s are a bit more expensive).
foamypirate is offline   Reply With Quote
Old 12-11-2015, 01:49 PM   #3
jamesjones
Freakin Awesome!
jamesjones's Avatar
Re: Van LQ4/4L80E
My LQ4 is from a van. No reason not to go with it at all. The only minor things you might have to change are the oil pan and power steering pump. The vans have a funky oil pan that is kind of big and the power steering pump is a weird remote reservoir one. They may work for your application but I needed to change them on mine.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 12-11-2015, 03:20 PM   #4
slotard
Re: Van LQ4/4L80E
I know the LQ9 has a few more ponies, but if I decide to throw a little boost at it the lower compression of the LQ4 might be nice. Not sure how likely that is, and I'll have to see how I like it NA before any real planning. I'll probably pull the heads, clean up any carbon, replace water pump, replace oil pan gasket, replace valve cover gaskets, probably put some LS9 head gaskets on, and that's about it for now unless there's something else important to do. I want streetable, not big power.
1973 C20, 350/350
Old 12-11-2015, 03:26 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Van LQ4/4L80E
I like van motors better. Most didn't tow, just had a lot of hours/per mile. I bought my oddball midyear van motor with like 60k on it and the cylinder crosshatch still looked brand new.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-11-2015, 07:38 PM   #6
ls1nova71
ls1nova71's Avatar
Re: Van LQ4/4L80E
Originally Posted by jamesjones View Post
My LQ4 is from a van. No reason not to go with it at all. The only minor thingsreallymight have to change are the oil pan and power steering pump. The vans have a funky oil pan that is kind of big and the power steering pump is a weird remote reservoir one. They may work for your application but I needed to change them on mine.
My van LQ4 had a truck oil pan on it, pretty sure they all do. Now dipstick and oil fill t ube, those were really long!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-11-2015, 08:08 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Van LQ4/4L80E
btw you might actually have a PS pump for a hydroboost equipped vehicle if its got 3 hoses.
Old 12-12-2015, 06:45 AM   #8
Tilt
Re: Van LQ4/4L80E
My 4L80 came out of a van. You'll want to find a truck dipstick to replace the original. The van one is LLLOOOOOOONNNGG.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 12-12-2015, 01:49 PM   #9
slotard
Re: Van LQ4/4L80E
Are all LS truck dipsticks compatible?
If it is hydroboost that would be nice, I'll have to see in person.
1973 C20, 350/350
Old 12-12-2015, 02:38 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Van LQ4/4L80E
They all interchange, just held in with the grommet at the bottom, and the lil bolt that braces it.
Know what manifolds your going to run first. Some of them interfere with dipstick position, and its a ton easier to modify the tube first if needed.
I actually like the van trans dipstick better, since it dumps out in an easy to reach spot, but it might hit the trans tunnel/firewall depending on your motor position.
Old 12-12-2015, 02:49 PM   #11
slotard
Re: Van LQ4/4L80E
I was planning on putting it fairly far back, don't see much reason not to.
1973 C20, 350/350
Old 12-12-2015, 03:40 PM   #12
ls1nova71
ls1nova71's Avatar
Re: Van LQ4/4L80E
Vans have remote mounted power steering reservoirs with a single big hose feeding the pump, the returns will be on the reservoir.
Old 12-12-2015, 04:50 PM   #13
slowcpe
slowcpe's Avatar
Re: Van LQ4/4L80E
My lq4/4l80e came out of a van. I've sine sold the trans since I'm going 6-speed. $1300 was a good deal.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-12-2015, 05:40 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Van LQ4/4L80E
Is that the case for all of them (HB and non HB)? My PS unit was off an Astro, which had 2 lines on the res,. but we switched to a truck HB which had all 3 onboard.
Old 12-12-2015, 05:42 PM   #15
slotard
Re: Van LQ4/4L80E
I'd like to be able to use it as a truck, and truck manual trannys aren't easy to find. Overdrive is a must, so the easy to find options are 4L80E, 6L80, 6L90. If I come across an NV4500 or NV5600 for the right price I'd be delighted, and probably go MS3 LSX PnP Gold... with an electronically controlled tranny I think I'm likely better off starting with a stock ECU.
1973 C20, 350/350
Old 12-12-2015, 09:55 PM   #16
ls1nova71
ls1nova71's Avatar
Re: Van LQ4/4L80E
I always just thought it was a van thing and that they all had them, but now that I think about it, I dont think I have seen a van with an LS engine that didn't have hydroboost. Maybe thats just the way vans were from around 2003 on up?
Old 12-13-2015, 12:46 AM   #17
slotard
Re: Van LQ4/4L80E
Uh, related... anyone know what kind of axle they come with? I guess it's unlikely it has the locker I want but it might be geared taller (4.10s on 30" tires aren't so freeway friendly).
1973 C20, 350/350
Old 12-13-2015, 01:11 AM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Van LQ4/4L80E
No clue, but its not usually worth running the late model rear axles IMO. The track width is off, and even some of the latemodel still had drum rears. Not much to be gained over a picking up an older 12 bolt and putting good axles in it.
Old 12-13-2015, 01:55 AM   #19
slotard
Re: Van LQ4/4L80E
My truck is a C20 so it has a 14FF that should be near impossible to break, I'd just like a posi of some sort (most likely a locker, that seems to be what's around) and 3.73s would work better for me than 4.10s. I'm pretty sure the 3/4 ton trucks of the era the van is have rear discs, don't know about the van. Doing spring perches and shock mounts isn't a problem for me, but I've never set up gears before, so the right deal on the right rear end is what I'm hoping for.
1973 C20, 350/350
