Old 12-10-2015, 11:58 PM   #801
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
My headers showed up just in time from Speedway. Got to test fit them before I yanked the motor.....
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-11-2015, 12:02 AM   #802
Coach529
Coach529's Avatar
Also notice the Sid's Modified Straight Axle is gone and on it's way to a new home!!
1949 Chevy 3600
Old 12-11-2015, 05:50 PM   #803
Elder Rogue
Elder Rogue's Avatar
Hummmm,,,,,
Going to take a wait and see on how this comes together.
This could be shear madness or pure genius.
Elder Rogue is offline   Reply With Quote
Old 12-11-2015, 06:09 PM   #804
ptc
ptc's Avatar
Wow that was a finished truck!!! yea I know they are never finished
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 12-11-2015, 07:22 PM   #805
Coach529
Coach529's Avatar
Originally Posted by Elder Rogue View Post
Hummmm,,,,,
It can either way.................
1949 Chevy 3600
Old 12-11-2015, 07:23 PM   #806
Coach529
Coach529's Avatar
Yea.....it will never be done!!
1949 Chevy 3600
Old 12-11-2015, 09:34 PM   #807
99 to Life
99 to Life's Avatar
digging those headers
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-12-2015, 09:55 AM   #808
Coach529
Coach529's Avatar
I was never really happy how the exhaust crowded the starter and master cylinder. A guy posted a picture of these on Facebook and I liked the idea. They were cheap enough ($179.00) from Speedway, so I thought I would give them a try.
A local truck (Gene, 1949 GMC) has a similar set up with cut outs. Might try to use his set up as inspiration, but not 100% sure. Love the hole in the fender......but I do not want to copy him on that.
Originally I was hoping to have the exhaust exit at the rear of the truck like the picture below. Not exactly sure at this point. Might be kinda of tricky getting the exhaust back inside the frame rails, plus I need to find room for all my air ride stuff. Lots to think about. ;-)
Might just use similar tips as below and exit out the running boards back by the rear fender.
1949 Chevy 3600
Old 12-13-2015, 10:19 AM   #809
Coach529
Coach529's Avatar
Had the afternoon available to get some stuff done.
Motor is now out and I have started stripping the leaf springs mounts and my old motor mounts.
1949 Chevy 3600
Old 12-13-2015, 10:24 AM   #810
Coach529
Coach529's Avatar
The rest of the front suspension install will be documented over on this thread.
Scott Danforth Crossmember Install
1949 Chevy 3600
Old 12-13-2015, 01:53 PM   #811
99 to Life
99 to Life's Avatar
sweet pics. Unfortunate the front clips usually get left outside, just got mine off and sitting outside yesterday. They sure look very cool though.
Old 12-15-2015, 04:36 AM   #812
lower50's
lower50's's Avatar
Coach point the dumps straight down below where he put them through the fenders. Could you run the exhaust under the frame just inside the running board brackets or outside the running board brackets?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-15-2015, 11:05 AM   #813
Coach529
Coach529's Avatar
I think I will fab up something similar to the picture below. If I install the flanges on the ends at a bit of an angle I can make it easier to get the exhaust pipe back underneath the truck.
1949 Chevy 3600
Old 12-15-2015, 08:32 PM   #814
Coach529
Coach529's Avatar
Parts are starting to show up...............yippee!!
1949 Chevy 3600
Old 12-15-2015, 08:38 PM   #815
99 to Life
99 to Life's Avatar
getting parts in the mail never gets old
Old 12-15-2015, 11:42 PM   #816
Coach529
Coach529's Avatar
Pretty damn awesome....
1949 Chevy 3600
Old 12-16-2015, 12:38 PM   #817
ptc
ptc's Avatar
Hey coach, what p/n did you order on the headers? and was it vehicle specific? I know they dont specify a set of over the frame headers for AD trucks with small blocks.... but how did they fit over the frame with good clearance and everything ok? What about your steering shaft? fit ok? Ive seen them mostly for the Tri-Fives using SBC and BBC engines... but nothing else.
Old 12-16-2015, 12:48 PM   #818
Coach529
Coach529's Avatar
They are more of a generic over the frame header. Below is a description from Speedway.
These small-block Chevy 265-400 V8 headers are designed for optimum performance in a variety of 1935-1948 fat-fendered street rod and pickup applications. Perfect for Gasser-style rods and drag cars, the fender well headers have long primary tubes that curve over the frame and through the fender wells. You must cut the inner fender panels to make them fit.
They fit pretty darn good for a generic header. If they were about 6" shorter between the 2nd and 3rd bend they would be about perfect.
I have about 1-1/2" between the head and the frame rails. I am in tear apart mode.......so I did not mock up my steering yet.
http://www.speedwaymotors.com/Small-...lain,3821.html
1949 Chevy 3600
Old 12-17-2015, 08:46 AM   #819
mikec4193
mikec4193's Avatar
Hey Coach
Was this not the same truck that you posted a picture maybe a month ago with a bunch of brush and sticks in the back bed???
Wow I am impressed....I come from the school...I build it once...if I don't like it I sell it...you keep changin stuff out on yours...super impressed for sure...
Tenacity I guess is what comes to mind...
love all the pictures...keep up the great work...and good luck...hope the money tree doesn't run out on you...
MikeC
mikec4193 is offline   Reply With Quote
Old 12-17-2015, 12:08 PM   #820
Coach529
Coach529's Avatar
Originally Posted by mikec4193 View Post
Hey Coach
MikeC
This is a family truck so it will never be sold.
1949 Chevy 3600
Old 12-25-2015, 11:57 AM   #821
Coach529
Coach529's Avatar
Still plugging away. Danforth Cross Member installed.
Need to mock up the motor for new motor mounts. After that the cab will come off and the frame stripped the rest of the way.
1949 Chevy 3600
Old 12-26-2015, 01:31 PM   #822
99 to Life
99 to Life's Avatar
nice job, making it look simple.
Old 12-26-2015, 08:44 PM   #823
Coach529
Coach529's Avatar
Stellar day in the shop today. Started out with some welding lesson's for my oldest son Ryder. He showed a ton of interest, so I figured might as well get him comfortable with the machines. Got the hang of it real quick. He welded up a bunch of scrap for the fun of it.
After that Ryder helped my get the motor back in place so I could figure out what I needed to do for motor mounts. Sure if a lot easier placing that motor and tranny with an extra set of hands.
I used a set of Chassis Engineering Motor Mounts when I originally installed the SBC. I was hoping to reuse them.
http://www.chassisengineeringinc.com...2-ton-pick-up/
I was concerned about the placement of the motor above the cross member. Sure looked like the motor would be placed higher and I was nervous about having to modify the floor of the cab to make room for the transmission. Once we got the motor and tranny in place It looked a lot better.
I modified the motor mounts and motor placement is about 1/4" higher than it was before. The intake is sitting at about 3-4 degrees without the full weight of the motor on the mounts. I think the full weight of the motor on the mounts will get me within the 2-3 degree spec. If it does not work, all it will take is a small spacer between the transmission and the cross member to get where I need to be.
The next step is the pull the motor again and final weld the motor mounts. After that the cab will get pulled and I will start on install the rear IRS.
1949 Chevy 3600
Old 12-27-2015, 12:32 AM   #824
99 to Life
99 to Life's Avatar
nice work, I like that protractor I'll have to look into that one. an extra set of hands makes all the difference. Iv done waaay too many two man jobs by myself. Nice to pass down some hands on skills to your kids. I'm hoping my daughter is a garage girl. shes almost 3 and loves tools already! crossing fingers.
Old 12-27-2015, 09:24 AM   #825
Coach529
Coach529's Avatar
It sure is fun involving the kids. All three of mine love the garage!!
The protractor is from Menards. Think they were less than $10 each.
1949 Chevy 3600
