Old 12-10-2015, 11:50 AM   #1
oski6754
oski6754's Avatar
Turn Radius - Left vs Right
I noticed recently that my turn radius when going left is about 30% better than when turning right. Has anyone had this issue or have an idea about what the issue might be?
Miles
1972 GMC Suburban K15 - Custom Deluxe
oski6754 is offline   Reply With Quote
Old 12-10-2015, 02:48 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Turn Radius - Left vs Right
Have any of the steering components been replaced? I would check the tie rod ends and see if they look equal as far as how many threads are showing on each end. I can't remember if the pitman arm is keyed to only go on one way or not but I think it is.....
LockDoc
Leon
Old 12-10-2015, 02:53 PM   #3
Bigdav160
Bigdav160's Avatar
I know my truck was that way when bought it.
All I remember is I had to back off the steering stop on one side to get the steering box centered. Then it was just a matter of adjusting the steering linkage.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-12-2015, 08:06 PM   #4
RANDY COX
RANDY COX's Avatar
My old Burb was the same way it turned waaaay sharper to the left then right, My dad's 71 GMC 4x4 truck was the same way, must be a thing with the 4x4's...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-14-2015, 03:42 PM   #5
oski6754
oski6754's Avatar
LockDoc
None of the steering components have been replaced, but I did install new leaf springs that are 2" over stock height. I'll take a look at the tie rod ends and pitman arm.
Miles
Old 12-14-2015, 04:19 PM   #6
LockDoc
LockDoc's Avatar
I don't know a lot about 4x4's but I would think installing the lift springs would shorten the drag link/pitman arm geometry on the drivers side.
LockDoc
Leon
Old 12-15-2015, 06:50 PM   #7
oski6754
oski6754's Avatar
That makes sense. I know they offer longer pitman arms for trucks with a 4"+ lift, but hadn't considered the effect with 2". Thanks LockDoc!
Miles
Old 12-15-2015, 07:04 PM   #8
Bigdav160
Bigdav160's Avatar
I have a two inch TC springs on my truck. I installed a dropped arm to get away from the bump steer (mild). Again, check those steering stops. Eventually that adjustment is what fixed mine.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
