![]() Join Date: May 2013
Reverse light wiring ?
I took out a 4 on the floor from a 67 , cant find the reverse switch wires , there is a yellow/orange and white wire coming from the bottom of the fuse panel , could that be it
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Re: Reverse light wiring ?
The yellow and white are for your interior cab light. The reverse lights "I believe" are purple and blue? and would be by your 4 spd coming from the firewall. If it still has the sm420 trans, its a one and last year deal for the reverse lights.
I found a 4 spade connector with a green and black coming off but dont know were it splices in harness , which wire going to the back powers the reverse lights ?
The reverse light wires should be dark and light green.
The dark green wire is the power feed that runs from the fuse box to the switch. Then the light green wire goes from the switch back to the lights. With the 4-speed trans, those dark & light green wires both run through the engine harness bulkhead connector on the firewall. That takes them outside the cab and to a 2-terminal plug that connects to the switch on the trans. Inside the cab, the light green wire just runs a short ways from the engine harness bulkhead connector over to the rear light harness connector. And from there runs to the back of the truck. |
#5 | |
Up and running , thank you , Ray
Here is a pic of the plug for a granny 4 reverse lite switch mine was located going down behind the passenger cly head
It's the one in front.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
