02-24-2004, 03:00 PM | #1 |
Relay wiring for Headlights???
I can't seem to find the diagram I am looking for for the Headlight relay conversion. I am installing the H-4 conversion from Rick's (great product) and need to know exactly how many and which relays to use. I have a couple of relays that are 4 prong, do I need 2 for each ligh (hi/low)?? Or do I need to get the 5 prong with the 87a terminal and run the 87 terminal to one light and the 87a terminal to the other light and use a 2nd relay for highs? Thanks in advance for the info. I will be posting picks of the original lights and new lights installed with and without relays.
Also, does anyone know which relay to use so the interior dome light will fade out slowly (like newer vehicles) when the door is closed? Thanks in advance! Thanks, Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-24-2004, 03:56 PM | #2 |
Here is a link that was posted a week or two ago...
http://www.classictruckshop.com/club...ead/lights.htm |
02-24-2004, 04:40 PM | #3 |
http://www.madelectrical.com/electri...adlights.shtml
This site is great@! http://www.madelectrical.com/index.shtml
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
02-24-2004, 05:02 PM | #4 |
You need to use SPST relays either 4 or 5 terminal, 5 terminal just has two 87 terminals. The 87A terminal is on the SPDT relay. Use one relay for low beam one relay for high beam both lights to same relay. Go to this link and click on "Click here to view catalog page"for a terminal diagram.
http://order.waytekwire.com/CGI-BIN/...7D7B71+M37+ENG
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-24-2004, 06:17 PM | #5 |
Thaks guys, that's what I'm looking for. Neonlarry, did you ever figure out the dome light dimmer relay??
Thanks again. Shawn
02-24-2004, 07:30 PM | #6 |
No, I haven't figured out the dome light. Give me a couple of year, make and model with them and I'll see what I can find out . I'd like something like that also to go along with the wiper delay switch I'm putting in.
02-24-2004, 08:05 PM | #7 |
its all about the +6 inches
Good link, good drawings, good reading. |
02-24-2004, 10:44 PM | #8 |
heres annother one.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
02-25-2004, 12:53 AM | #9 |
Here is a link to a circuit diagram.
Most all the parts should be available at radio shack.
02-26-2004, 12:18 AM | #10 |
Junior Member
Relays
I was able to find the relays at radio shack for $6 bucks a piece
Old Chevys never die they are just reborn! |
02-26-2004, 01:13 PM | #11 |
Call 1-866-866-1315 autothisworld I think that have the fading dome light I know they have the one touch up and down for power windows for $39.99. If they dont check some street rod mags. I know I saw it.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
03-07-2004, 03:58 AM | #12 |
Out of the carpool lane.
I finally got around to doing the headlight conversion on my truck today. I live in a big city with lots of street lights so it's kinda hard to tell the difference but I think there's a little more light now. I haven't had a chance to flip on the high beams and I'm curious how they will look now. Btw, if it's still not enough light after I readjust my lights, I've got a box with the H-4 style lamps with 85/100 watt beams!
I wanted to do this on my practice vehicle (my truck) before I do this to my Camaro. Not too difficult, just took about 1/2 a day and some connectors to make everything look stock.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
03-07-2004, 03:01 PM | #13 |
here's another link headlight upgrade
02-22-2005, 09:19 PM | #14 |
Dome light dimmer
I got a dome light fader from Web Electric.
http://www.webelectricproducts.com/products.htm It works great. Model DLD-1 Dome Light Dimmer Module. I installed it next to the fuse box and hooked into the dome light wiring right there. I also installed two under dash lights to light the footwells and hooked them in. Lights fade out in twenty seconds when the door is closed but go out instantly when the key is turned or the truck is running. I didn't have doorswitches so I installed them in the rubber bumper holes at the top of the doors... much easier to wire and no drilling.. Drilled out the bumper and it fit over the switch too. |
02-22-2005, 11:13 PM | #15 |
I got mine from Radio Shack. The numbers are listed on the bottom of the relay and on the back of the package.
12VDC/30A SPST Automotive Relay $6.29 Catalog #: 275-226 Model: 275-226 |
02-22-2005, 11:23 PM | #16 | |
User #12137
now i am woundering if i can find the rite kinda thingy for the timed dimer dome lights ? |
02-27-2005, 10:31 PM | #17 |
Not a bad nut after all..
For those that have used the Radio Shack style relay, did you mount the relay to the radiator support with a self tapping screw and then use crip on wire connectors to attach to the relay? Anybody have any ideas to make this neater?
02-27-2005, 10:42 PM | #18 |
Go to the junk yard, look on the drivers side firewall on a square body fuel injected S-10. Grab the two relays, and cut the harness a good 6 or 8 inches down. Now the splices you'll make will be hidden and protected in the harness, and the connector will be water tight.
07-28-2005, 03:22 PM | #19 |
If you have a GMC where we have 2 of each head light where Chevy has 1 of each head light, do we need 4 of these relays? Or is it not possible with GMC's?
07-28-2005, 06:16 PM | #20 |
Tanker,
The concept is the same. One relay for low beams, one for the high beams. Only your wiring will be slightly different....I'm guessing not knowing the wiring diagram.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
