12-15-2015, 06:57 PM | #1 |
Door Alignment
I could use a little help on this one, on my 72 4x4 pickup I am getting ready to replace inner and outer rockers I want to make sure the door is aligned before I start so when I put on the rockers on it is right. In the picture below the door is out quite a bit from the rocker in the front the back of the door is fine and it is in as far as it will go at the hinge. Looks like the rocker was replaced before do you think who ever installed it didn't align it properly (will I be able to move the new rocker out that much 1/2" ?)or maybe there is a problem with the door ? door is not rusted and looks like original skin.
Anyone run in to this before ? Thanks John |
12-16-2015, 01:03 AM | #2 |
Re: Door Alignment
The door is sticking out too far
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-16-2015, 01:05 AM | #3 |
Re: Door Alignment
You also need to check and possibly replace or rebuild the hinges first
12-17-2015, 12:12 PM | #4 |
Re: Door Alignment
Yes hinges were rebuilt, anyone else run in to this ?
Thanks John |
12-17-2015, 12:20 PM | #5 |
Re: Door Alignment
Start with getting the door aligned with the back of the cab, and up/down. That means you no longer mess with the hinge part that's bolted to the cab, so you can eliminate that movement. Then align the fender to the front of the door, rocker, and cowl.
Once all of that is done, you can fine tune the door by moving it in and out. Move it in and out to align it with the fender with the hinge bolts on the door. Then realign it in/out with the back of the cab by moving the door striker in/out. If none of that works, you can shim out the bottom of the fender and try realigning the rocker if you still think it was done wrong.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
