Old 12-18-2015, 05:26 PM   #26
SCOTI
SCOTI's Avatar
Re: The Tiki Sea 10
Originally Posted by DaddyOh View Post
Also... final rough fit before clean-up on the back window.
Any issues w/the window seal? What brand used?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2015, 05:58 PM   #27
jlsanborn
jlsanborn's Avatar
Re: The Tiki Sea 10
Man I totally dig the off-road scene you're into. I had a pretty cool Baja back in the day. Swear I'm going to do another one day. Your work is outstanding!!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 12-18-2015, 06:08 PM   #28
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Bought rubber from Precision Replacement... worked fine for the 3/16" replacement glass, did not like the 1/4" glass. I Ended up wanting to use 1/4" green glass, had a piece cut locally (due to wanting all glass be the same shade of green) and bought a "Trim-Lok" piece of window rubber for 1/4" glass and 1/8" sheet metal from glass supplier/cutter. The picture shows the older glass with rubber, will post updated when fit the new... the old glass was installed to double check the clearance between rubber and glass - .22" to .25"
The window rubber, it seems, is nothing unique... appears to be the universal two piece locking rubber that can be found at most auto glass suppliers. Your results might vary... my experience
EDIT: The Precision rubber looks like it is sized for 1/4" as well. The window opening still needed 'massaging' when initially installed. That said, it just looks like the ordinary 'universal' two piece strip. The bigger issue is the glass... ended up buying the back glass 3 times... the quality of the cut and polishing are hit/miss.
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356
DaddyOh is offline   Reply With Quote
Old 12-24-2015, 06:14 PM   #29
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Gauge cluster rebuilt... had Ron over at Williamson Instruments work his (and his wife's) magic:
Wanted an original looking cluster to work with the 5.3l/4l65e.
All gauges rebuilt and set-up for electronic senders
All new lenses
6000rpm Tachometer
1969 Corvair clock converted to Quartz movement
Cable X control module for electronic speedo
Some more 'magic' to come on my end but is coming along...
Old 12-24-2015, 08:38 PM   #30
ChrisDollins
ChrisDollins's Avatar
Re: The Tiki Sea 10
Wow that looks awesome! They really did a good job.
Chris
ChrisDollins is offline   Reply With Quote
Old 12-27-2015, 04:52 PM   #31
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Backend is mocked in to check inner wheel (wheel lip) clearance... and to check stance. Now ready to tear all sheet metal off and send to painter and work on chassis mods...
18x8 wheel, 255x55x18 tire, 4.5" backspace (4" drop in rear, front will be 2.5" drop spindle with 1" drop coil)
No clearance of inner lip needed, clearance approximately 2"
Old 12-27-2015, 05:45 PM   #32
Indyfab
Indyfab's Avatar
Re: The Tiki Sea 10
Is your rearend stock width? What are you using for the front suspension, I mostly curious as to the difference in the new WMS compared to the old WMS measurements. I am going to order my wheels soon, and I'm trying to compare combinations that I like the look of.
Indyfab is offline   Reply With Quote
Old 12-27-2015, 05:55 PM   #33
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Rear end is stock width (12 bolt) with Baer big brake disc...
Old 12-27-2015, 06:01 PM   #34
Indyfab
Indyfab's Avatar
Re: The Tiki Sea 10
Thanks for the info, so many are swapping a 1971 or 1972 rearend in for the pattern change which makes it 1 1/2" wider.
Old 01-01-2016, 06:48 PM   #35
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
From this...
To This...
Matte finish powdercoat (ivory) to match bumpers/wheels and an offset powdercoat (tan) in matte finish for bezels and grille insert.
Only takes 101 individual steps... For something so basic, it sure has a lot of individual parts! The grille will have a detachable 'mil-spec' harness and a daylight running module once installed.
Old 01-01-2016, 08:29 PM   #36
clemdaddy
clemdaddy's Avatar
Re: The Tiki Sea 10
very nice work. really like the 60 grill and that cluster is killer. are you going static drop or is there bigger drop in the works?
clemdaddy is offline   Reply With Quote
Old 01-01-2016, 09:53 PM   #37
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Thanks Clem, just a simple static drop... will be keeping it a "Freeway Flyer", just something to hop in and drive to Arkansas without a worry..
Old 01-07-2016, 03:21 AM   #38
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Quick benchtop test to check bleedover (need to correct left turn area) and, more importantly, ask the wife which color she wants... it will be green.
Now to figure out how to incorporate a High Beam indicator, Check Engine indicator and Cruise Control power into the cluster.
Old 01-13-2016, 02:43 PM   #39
Pro Performance
Pro Performance's Avatar
Re: The Tiki Sea 10
Like where you are going with it, and will be looking forward to seeing it come together!
Pro Performance is offline   Reply With Quote
Old 01-30-2016, 10:50 PM   #40
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Looking at fixing/updating the lower door after (as many of you know) it has been hacked to fit a speaker. Using it as an opportunity, I did not like that access to the lower section of the door is limited... I wanted access for sound deadening, ease of glass install and make installing power windows and locks a little easier.
Burned these out (with cut template) on the plasma and will bead roll them in a few variations: 1, the 'stock' bead roll pattern and 2, a bead roll pattern that allows for a speaker install without looking out of place. Trying to 'update' while keeping some of the original 'feel'... even used the same fastener pattern.
Found these Custom plaques at a swap meet and will be using them somehow... that's the direction, will post update once finished bead rolling.
Old 01-30-2016, 11:41 PM   #41
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: The Tiki Sea 10
I like!
I didn't have a need for these, but woulda been cool!
Very great idea!
Modges'66 is offline   Reply With Quote
Old 01-31-2016, 12:13 AM   #42
60chevyjim
60chevyjim's Avatar
Re: The Tiki Sea 10
wow that's a great idea , it would be nice to do that on my friends truck that im building so I could get inside to repair a large dent in one of the doors .
60chevyjim is offline   Reply With Quote
Old 01-31-2016, 12:22 AM   #43
Indyfab
Indyfab's Avatar
Re: The Tiki Sea 10
I think those are a great idea, I've got a bad dent in one door that I think I could get out if I had better access, you might have given me the answer.
Old 01-31-2016, 02:26 PM   #44
Bomp
Bomp's Avatar
Re: The Tiki Sea 10
Late to the party, here til the end.
Sub'd
Bomp is offline   Reply With Quote
Old 01-31-2016, 03:04 PM   #45
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
Access to the inner door is pretty good now, you can see in the pics. Just a CAD 'cut template' which gives a grinding line to follow that will align the J-nuts to attach the lower panel. Will post bead patterns after they get worked out. Thanks
Old 02-23-2016, 01:13 PM   #46
DaddyOh
DaddyOh's Avatar
Re: The Tiki Sea 10
...while waiting for new parts to arrive, bought a new toy for the shop. Playing around to learn the new beadroll machine... haha
Homage to Willy Wonka - J. York drawing
Now back to work
Old 02-23-2016, 02:17 PM   #47
goatless
goatless's Avatar
Re: The Tiki Sea 10
Now back to work
You learn quickly!
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 02-23-2016, 03:47 PM   #48
siggyfreud
siggyfreud's Avatar
Re: The Tiki Sea 10
Awesome work! Will be following this one!
siggyfreud is offline   Reply With Quote
Old 02-23-2016, 08:54 PM   #49
jlsanborn
jlsanborn's Avatar
Re: The Tiki Sea 10
You did that with a bead roller!? Damn dude, you could make some mad sh!t with that!
Old 02-24-2016, 09:13 AM   #50
clemdaddy
clemdaddy's Avatar
Re: The Tiki Sea 10
man… i really like that door panel idea. so many of the doors have been cut for speakers and it takes a ton of time to fix them, never liked the factory door bottom as it is weak, like old dies were used and the replacement panel isn't even close. your idea solves a bunch of problems… gonna steal that one.
nice work...
