Closed Thread
Old 12-18-2015, 07:43 PM   #1901
chevy2tom
chevy2tom's Avatar
Re: What did you do to your truck today part III
It's mine lol
It's a bench from a mid 90's full size chevy truck it even has an arm rest that tucks away for the driver
chevy2tom is offline
Old 12-19-2015, 02:24 AM   #1902
Grizz1963
Grizz1963's Avatar
Originally Posted by jturner18 View Post
Nice driveway!
Thank you.
"Block paving" as it is known here in the UK is popular and reasonably priced.
The guys who lay it will do an area like this in under a day. They work like machines.
This was that section looking the other way toward the house and where the woodwork shed went.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 12-19-2015, 11:41 AM   #1903
LT1 Burb
LT1 Burb's Avatar
Block, primer , block, primer, repeat, sore shoulder, want finished.
LT1 Burb is offline
Old 12-19-2015, 07:31 PM   #1904
craiginaustin
craiginaustin's Avatar
Installed the sway bar I cleaned and painted last weekend. Painless install, drilling holes in the frame was a bit nerve-wracking but easy enough in the end. My LCA's already have the holes so no modifications required there.
It handles remarkably better... less feeling like a boat, more actual turning.
craiginaustin is offline
Old 12-19-2015, 10:03 PM   #1905
PORKY
PORKY's Avatar
We got the doors back on. It's starting to look like a truck again.
PORKY is offline
Old 12-20-2015, 12:05 PM   #1906
jbgroby
jbgroby's Avatar
Got the horn button installed, do not quite yet if it will work, but there is always the 'fingwr'.
jbgroby is offline
Old 12-20-2015, 12:51 PM   #1907
chevy2tom
chevy2tom's Avatar
Thumbs up Re: What did you do to your truck today part III
Nice gauge set up
Old 12-20-2015, 02:16 PM   #1908
jbgroby
jbgroby's Avatar
Thanks, I followed the OEM light setup and added the OEM click and tack
jbgroby is offline
Old 12-20-2015, 05:46 PM   #1909
oldies1938
I put glove box lock and under dash ashtray knob and snuffer on
oldies1938 is offline
Old 12-20-2015, 11:26 PM   #1910
AngryPirate
AngryPirate's Avatar
Got the cab stripped down to nothing. Just glass to remove and its time to start blasting.
Then I'll be onto what LT1 Burb is doing.
Any tips on removing windshield and back glass?
AngryPirate is offline
Old 12-20-2015, 11:26 PM   #1911
PORKY
PORKY's Avatar
We got the firewall painted today.
PORKY is offline
Old 12-21-2015, 07:08 PM   #1912
Slambone
Slambone's Avatar
Lowered the front of my truck another inch and the back another 2 inches. 7/9 drop now. found some super short shocks at Mooneyes. Getting those this week.
Slambone is offline
Old 12-21-2015, 07:40 PM   #1913
LT1 Burb
LT1 Burb's Avatar
Just razor knife it out and be careful of the stainless trim, don't force it.
LT1 Burb is offline
Old 12-21-2015, 07:44 PM   #1914
jturner18
Talking Re: What did you do to your truck today part III
Well...I was just going to start with the headlight rebuild and ended up here. Guess I'll do a frame off now. Ha!
jturner18 is offline
Old 12-21-2015, 08:07 PM   #1915
AngryPirate
Thanks LT1 Burb.
Old 12-22-2015, 07:29 AM   #1916
Grizz1963
Grizz1963's Avatar
I feel your pain.
Old 12-22-2015, 09:29 AM   #1917
pimpston65
pimpston65's Avatar
i used a durablock 48" call it black mamba. well that and about 3 others sizes!!!
pimpston65 is offline
Old 12-22-2015, 07:42 PM   #1918
PORKY
PORKY's Avatar
Was there 4+ years ago, still there. I've just recently started back at it. We were just going to replace rocker panels and got into a full frame off.
But we are gaining. Stay with it, a little each day and soon it'll be done.
Best of luck!
PORKY is offline
Old 12-22-2015, 11:18 PM   #1919
mehoff400
getting ready to pull the engine. think all is left is unbolt motor mounts and remove driveline.
mehoff400 is offline
Old 12-23-2015, 12:01 AM   #1920
racecougar
racecougar's Avatar
Took 7" out of the original '65 12-bolt and installed a pair of Moser 7950 housing ends. These ends retain the stock brake mounting pattern while converting to the big Ford 3.15" axle bearings and retainer plates, thereby eliminating the need for C-clips.
The housing is now 50" end to end. It was 57" originally; already 1-1/2" narrower than the later truck 12-bolts.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 12-23-2015, 12:24 AM   #1921
DKfromIA
Originally Posted by Alberta65 View Post
Hey I guess this is my first post but it's time to get in on the action:
finished up the bed yesterday..
[IMG][/IMG]
Nice looking bed. What wood did you use? Did the diamond plate come in a kit or did you fab that yourself?
1966 GMC LWB Fleetside
DKfromIA is offline
Old 12-23-2015, 11:16 PM   #1922
TJ's Chevy
TJ's Chevy's Avatar
Fired up my GMC after 2 weeks sitting and ran her for awhile. She was happy I paid some attention to her.
TJ's Chevy is offline
Old 12-24-2015, 02:14 PM   #1923
vince1
-15C (5F) so I just plugged it in and came in for a coffee. Today it gets to drop a stove off at the recyclers. It will be interesting to learn how she handles the fresh snow without the aid of positrac.
vince1 is offline
Old 12-24-2015, 02:49 PM   #1924
doobiebro
doobiebro's Avatar
looks just like my replacement cab going on my 60 chevy.. Only thing is its a GMC cab and I will change out dashes..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 12-24-2015, 05:59 PM   #1925
TJ's Chevy
TJ's Chevy's Avatar
Its cold out here and my GMC didn't have a working heater, so I took the blower motor out to find it was seized up solid. Put one in that I got from my 66...well...now I have freezing ice cold air. lol But hardly a touch of heat. Took the top off and the core had pine needles and crap on top of it...vacuumed that off...sill no heat. Thinking my core is plugged up or something. Will be taking the core out Saturday to see if the fins are still plugged. If they are I'll blow them out and if that doesn't help I'm throwing a new core in. Probably not a bad idea considering this one is 50 years old anyhow.
EDIT: One of the vents was open letting cold air in. lol Closed that and problem solved. Time for some driving in the snow! Oh yeah...I did a burn out to while I drove it earlier today. haha
Closed Thread
