Old 12-16-2015, 10:56 PM   #1
6xchevy
Engine Paint
Howdy, what kind of primer and paint do you guys use on 50 year old motors that will stick and look good for longer than two months? Any favorite kind of degreaser you guys like? Thanks.
6xchevy is offline   Reply With Quote
Old 12-16-2015, 11:15 PM   #2
hugger6933
Re: Engine Paint
The key is getting it clean some times I have used oven cleaner. Now the spray can type paint is ok, but get one with ceramic in it they will last longer.
on my ones that i really want to look sharp I'm gonna prime them with epoxy primer then spray the paint on with the paint gun.I have one I'm gonna epoxy prime then high build then paint the high build should smooth out a lot of the casting.The prettiest I've had I had the sanding castings sanded smooth on the block it was so pretty. As with any successful paints the key is in the prep work the more you put in the better the result will be. Jim
hugger6933 is offline   Reply With Quote
Old 12-17-2015, 12:36 AM   #3
Rod Run
Rod Run's Avatar
Re: Engine Paint
Prep is definitely the key. Even when I think I did "good enough", I always go one step further with the cleaning.
I start with degreaser, then I will usually use a wire wheel attachment on my hand drill and wire brushes. An acetone wipedown is next. From there I might use sandpaper sometimes.
Next comes another acetone wipedown, followed by lacquer thinber. I use regular self etch primer topped off with high heat paint (all spray can stuff) and that holds up for years.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 12-17-2015, 12:57 AM   #4
70cst
70cst's Avatar
Re: Engine Paint
http://67-72chevytrucks.com/vboard/s...d.php?t=564585
http://67-72chevytrucks.com/vboard/s...d.php?t=179867
This might help
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-19-2015, 01:30 AM   #5
Z10
Z10's Avatar
Re: Engine Paint
I used Brake cleaner on mine and worked pretty well. Buy about 10 cans and get after it.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-19-2015, 10:46 AM   #6
Re: Engine Paint
What makes paint stick is one thing, a spankin' clean engine. All I've ever done is paint straight-up engine paint, that's it, no primer. Whenever possible, I like to warm the engine or parts as much as possible, before and after.
