Old 12-19-2015, 11:57 PM   #1
aotte1
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
Looks nice, good luck with it. My '86 stepper came with one originally, and below are a couple of photos. I believe the shifter, boot, and knob to be original. Only thing I changed was the speedo cable seal, otherwise original. Have changed and upgraded the engine a little over time. No power shifting, however, works great once in gear and getting on it (400 HP/400Ft-LBS @ 5600RPM). The overdrive is very nice, with 3.73 gears. I like the 3.73 gears for first too, you can go slow in first if needed.
aotte1 is offline   Reply With Quote
Old 12-22-2015, 11:25 AM   #2
Keith Seymore
Keith Seymore's Avatar
Correct - your shifter, boot and knob are original (appearing) for '86 and '87.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
