4" drop axle
hello i have a 4" drop axle on a 1950 gmc truck can anyone tell me shock length needed and good brand of shock they have used
Hollister Road Co.
Re: 4" drop axle
Should be the stock shock length. look it up on rockauto.com
Re: 4" drop axle
Yep, the shock length doesn't change with a dropped axle. The axle is in the same spot it was before it was dropped in relation to the frame it's just 4 inches closer to the ground.
Re: 4" drop axle
thanks for replys so when i look at the POL catalog for instance they list a shock for a 3-4" drop is that more for a mustang II front end
Hollister Road Co.
Re: 4" drop axle
Yes Mustang, S10 any suspension that uses A frames and coil springs to drop the vehicle. The drop axle your just stretching the spindle end upward and leaving the spring to axle distance alone.
Re: 4" drop axle
thank you
