Old 12-20-2015, 06:42 PM   #1
Mrturner1
How do I tighten power steering belt?
Looks like a piece is missing but pump doesn't move
Mrturner1 is offline   Reply With Quote
Old 12-20-2015, 06:45 PM   #2
mikeshome
mikeshome's Avatar
Re: How do I tighten power steering belt?
When someone put your headers on the extra bracket was removed,There should be two other bolts holding it and it should move to get your belt tight.
mikeshome is offline   Reply With Quote
Old 12-20-2015, 06:50 PM   #3
Mrturner1
Which two bolts?
Old 12-20-2015, 07:45 PM   #4
El Dorado Jim
I will takesome pics of mine and post them
El Dorado Jim is offline   Reply With Quote
Old 12-20-2015, 09:53 PM   #5
frankslagoon
I'll take a guess and say the PO pushed the pump all the way to the inside of the adjustment and then found a belt that they could squeeze on there. that's why ya can't move it. you are missing a piece. I bet it wrapped around and bolted to the exhaust manifold. My 70 is a big blk so wait for Jims pics.
frankslagoon is offline   Reply With Quote
Old 12-20-2015, 11:01 PM   #6
El Dorado Jim
took some pics , came out tooo dark, will try again tomorrow
Old 12-20-2015, 11:22 PM   #7
frankslagoon
I think this is it, nope not the same.
Old 12-21-2015, 07:59 AM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: How do I tighten power steering belt?
Look up under the pump. There should be a bolt that connects it to the brace on the front side that since they didn't use the other brace they tightened the crap out of it. Loosen it and the whole pump should move away from the water pump.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-21-2015, 04:39 PM   #9
El Dorado Jim
raining today, can't get pics today, will get them when I can
Old 12-21-2015, 06:42 PM   #10
El Dorado Jim
Hi, look under the 1973-87 pickups, message board , find "restoring rusty" by "Gregski" on pg. 58 of his thread, he has pics of exactly what you have and the piece you are missing, it is the piece that bolts to the end hole of the exhaust manifold, someone removed it when they installed headers,you will have to fabricate a new piece, good luck
Old 12-21-2015, 06:52 PM   #11
midniteblues
midniteblues's Avatar
Here is one. I think gm made these in differnt styles.
The problem is getting one too work with headers.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-21-2015, 07:28 PM   #12
michael bustamante
michael bustamante's Avatar
i used an alternator slotted bracket from the 250 from our era trucks. i bolted it to the top threaded hole in the head
1967custom
michael bustamante is offline   Reply With Quote
