![]() Join Date: Aug 2008
WTB Big Block LWP AC brackets Driver side & AC lines Axial
I recently swapped a 73 454 big block out of a 73 C20 into my 79 Malibu. For simplicity's same I kept the long water pump, pulley and brackets. The truck/ engine originally had AC but it had been removed before I bought it. I am thinking of using the original brackets and hoses. From my experience all of the fitting on older GM vehicles were the same. I plan on running one of the newer r134 compatible axial compressors.
I will need all of the AC brackets (and bolts if possible) and a good set of hoses that run from the compressor an to the evaporator and condensor. Compressor not needed. Price shipped to Cedar Park Tx 78613 (NW of Austin) |
Re: WTB Big Block LWP AC brackets Driver side & AC lines Axial
I will look to see if I still have a set of a/c brackets . if so I would ship them to you for $60. Pm me if interested so I don't forget.
Several years ago I bough new lines at one of the parts stores. It was cheaper than having my lines repaired with new rubber. Frank
Born and proudly residing in a Red State ! |
I've got a set of BBC AC brackets-they've been blasted and painted a high temp satin black and cleared. All hardware included. I can do $150 shipped.
I made a quick run through the barn and found these. Its incomplete . I may be able to find the other parts if I can get home in the daylight. I will let you know .
Frank
#6 | ||
I didn't get a notification that you had posted again, so if you find the rest I them but don't hear from me, send me a pm, please. |
I will look again in the barn when I can get out there in the daylight. I will let you know.
Frank
F.monroe- any updates?
I have not been able to find the top bracket. I will look again but I can't promise anything.
Frank
