Old 12-22-2015, 12:01 PM   #1
Desert1957
Desert1957's Avatar
Long Bed To Short Bed Question
I am trying to decide to convert my 87 "Long Bed" to a short bed.
Have see all the articles and threads on the frame mod, But what are my options with bed?
I would like to by all new panels and build a replacement short bed.
Can this be done?
Dez
This
To This
Name:  003 - Copy.jpg
Desert1957 is offline   Reply With Quote
Old 12-22-2015, 01:14 PM   #2
daddyjeep
daddyjeep's Avatar
Re: Long Bed To Short Bed Question
LMC Truck has all or the pieces to build a brand new bed. Stacy David on Gearz TV has done it on a couple of episodes and I think Trucks did too on The Spike Network's Power block.
daddyjeep is offline   Reply With Quote
Old 12-22-2015, 02:14 PM   #3
SkinnyG
SkinnyG's Avatar
Trucks! show did a '66, where they cut the box down. You should be able to find enough of the episodes on Powerblock's website.
There was a video (show?) series on YouTube where some guys shortened a square and cut down a box, but the episodes didn't completely finish it. They just cut off the front and back the correct amounts.
With a welder and a cutting disk, you can do anything. It's just time. I was going to cut down my longbox, but found a local shortbox for less than the cost of replacement wheel arches for mine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-22-2015, 04:43 PM   #4
68c10owner
68c10owner's Avatar
The besides LMC sells don't have the fuel doors in them. Might not be a issue. It's easy enough to cut the bed down. If you can handle the frame mods the bed mods are nothing.
EDIT- I was wrong, LMC does sell the bedsides with either round or square fuel door holes.
Anthony
Last edited by 68c10owner; 12-23-2015 at 03:52 AM. Reason: Updating correct information
68c10owner is offline   Reply With Quote
Old 12-22-2015, 07:07 PM   #5
tinydb84
tinydb84's Avatar
I think cutting the bed down would be harder and more time consuming than doing the frame.
http://www.73-87.com/7387garage/chas...lwb_to_swb.htm
David
Instagram: myfabguy
Old 12-22-2015, 07:11 PM   #6
68c10owner
68c10owner's Avatar
I personally have not shortened a truck but I would never do it the way shown in your link. A straight cut to me seems not quite as strong as a "Z" type cut would be and then plating the inside of the frame for extra support.
Cutting the bed own is a lot easier unless you are not handy with a welder. Easy to burn through sheet metal but this is not really a beginner fab job.
Anthony
Old 12-22-2015, 07:17 PM   #7
tinydb84
tinydb84's Avatar
I agree with the "Z" cut. The link has all the info regarding the measurements, springs, gas tank, etc. though.
Welding the bed is one thing. Welding a long vertical line in sheet metal is a whole other animal. If you don't know what you are doing it would be real easy to warp the hell out of it.
MARTINSR wrote a really good post in the body section demonstrating how he would lay out he lines and where to cut. If I find the post I will put a link up.
David
Instagram: myfabguy
Old 12-22-2015, 07:21 PM   #8
68c10owner
68c10owner's Avatar
I would be more worried about doing the frame correctly because of that fails someone could loose a life. If they bed intimidates you, find a short bed on craigslist. Its really not that big of a deal if you do it in sections. You just need to know how to weld sheet metal.
I dont know how the squares compare to the 67-72 trucks but I know you take 12" right behind the cab and the last 6-8",cant remember if its 6 or 8, from the end of the frame.
Another option would be finding a short bed frame.
Anthony
Old 12-22-2015, 07:36 PM   #9
tinydb84
tinydb84's Avatar
Here is the thread. Lots of good info in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=640898
David
Instagram: myfabguy
Old 12-22-2015, 08:43 PM   #10
slotard
I agree that doing the frame right is far more important than the bed. An ugly bed is very unlikely to kill anyone. Do a Z and fish plates.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-22-2015, 09:00 PM   #11
68c10owner
68c10owner's Avatar
But are the 73-87 trucks the same as the 67-72 trucks? If not that info doesnt work in this case. Great info for sure if your doing a 67-72 though.
Anthony
Old 12-22-2015, 09:03 PM   #12
tinydb84
tinydb84's Avatar
The first link I posted had all the 73-87 info. The second link is for layout, body work, etc.
David
Instagram: myfabguy
Old 12-22-2015, 09:04 PM   #13
68c10owner
68c10owner's Avatar
That first link didnt really offer much other than text on how to do it. There have been tons of threads on here about the conversion. Pictures tell 1000 words.
Anthony
Old 12-22-2015, 09:26 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Can this be done?
Dez
If that is a picture of your truck, and its as clean as it looks I would not convert it. I'm not in the least bit opposed to cutting up a truck, but that looks to be a really clean original truck. Unless there are sentimental reasons, you would be much better off selling that one and buying the SWB you really want.
With that said, if your set on cutting your down use the z cut as mentioned. Bedsides can be cut and welded, but if you have to ask my guess is you dont have the ability to cut and weld sheet metal that thin with out warping it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-23-2015, 01:52 AM   #15
izzy_Britton
izzy_Britton's Avatar
They used to offer the bedsides with or without fuel holes... wth? good know know, glad you pointed this out.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 12-23-2015, 03:51 AM   #16
68c10owner
68c10owner's Avatar
Ok, had to double check and it appears I was wrong. LMC does offer them with round or square holes. It must have been Brothers that sells them without the fuel door hole. Those are the only 2 square body catalogs I have and I know one of them sells them without the holes because I remember thinking that was strange but since I dont need bed sides I didnt really worry about it.
Anthony
Old 12-23-2015, 03:55 AM   #17
68c10owner
68c10owner's Avatar
Just looked, Brothers is the one who sells them without holes but they do offer them in round or square hole as well. guess i better know what the hell Im talking about first, huh? LOL. sorry for the bad info guys.
Anthony
Old 12-23-2015, 09:11 AM   #18
Desert1957
Desert1957's Avatar
OH NO, Now I have to revisit this question again. I have been told by many who have seen my truck, Don't cut it up.
I acquired this truck 25 years ago for $100.00, with a knocking motor. Its a plain jane , heavy half but Its followed me around for years. Yes part of the family now. Even my wife has changed her mind about me selling it, Go figure?
I guess I should have said in my OP that I may have access to a SWB complete frame. That was why I was going to build a bed. Swap it all out for a nice winter project.
Still could go back to a long bed if I keep everything.
Sounds crazy HUH?
Desert
Old 12-23-2015, 09:24 AM   #19
Desert1957
Desert1957's Avatar
Here is a pic before the drop. Frozen morning after I changed the wheels.
Name:  Blue truck 1 - Copy.jpg
Old 12-23-2015, 12:07 PM   #20
Keith Seymore
Keith Seymore's Avatar
Your CRAZY!!!!!!!!
I'm a shortbed guy but that one looks pretty good even as a longbed (especially with the rallys).
I'd leave it alone and pick up a short bed truck (or not).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-23-2015, 12:28 PM   #21
Desert1957
Desert1957's Avatar
K
I Know, you guys are giving me a reality check.
Thanks......
Old 12-23-2015, 01:13 PM   #22
68c10owner
68c10owner's Avatar
Thanks......
It is a clean truck. Im a shotbed guy as well but I would drive the tires off of that one. I would just enjoy it and maybe look for another truck for a project. Grab that shortbed frame if you can and use it to build something. You can get cabs and other body panels on craigslist all the time. Or even another long bed that isnt quite as nice to cut up. THey tend to be cheaper to buy than the shortbeds.
Anthony
Old 12-23-2015, 03:29 PM   #23
Bigstevex4
Bigstevex4's Avatar
cutting the frame is nothing. we have dozens of e450s that the frame has been cut and lengthened its standard practice in any truck build shop. And I wouldn't shorten it. If it were mine.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 12-23-2015, 04:06 PM   #24
Fatherof3
Fatherof3's Avatar
You want a short bed, cut it. The world wont miss it not being long.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 12-23-2015, 04:23 PM   #25
slotard
I'd be more worried about lengthening than shortening, as even with the same load the bending moment increases when you lengthen the frame. Then again, for all I know different van lengths all use the same frame height/width/thickness so it may not be an issue.
I agree that, done right, there's nothing wrong with shortening. That said, it does need to be done right. It shouldn't be your first welding project, and you shouldn't try to do it with a 110V MIG. It's a life safety issue, so it needs to be done by a competent welder with the right equipment.
1973 C20, 350/350
