09-17-2015, 10:22 PM | #1 |
Can someone please straighten me out?
I have a 1965 C10 stepside everything is refreshed or new and I have drop spindles and shorter shocks and springs. I've had the 4 wheel alignment done several times and the truck rides awesome but it feels a little squirrelly over 70mph. Truck drives dead straight everything feels nice and tight and solid just like it should. Does anyone know the correct info to tell these guys doing the alignment for me?
09-18-2015, 06:26 AM | #2 |
Re: Can someone please straighten me out?
I replaced my steering box with the close ratio box from Brothers back a couple years ago when I did the suspension and tie rod ends.
09-18-2015, 06:26 AM | #3 |
If they are setting it to the factory specs it will have very little caster in it. Go to these two threads and do some reading. I have done the caster mod and have 5 degrees in my truck. Makes a world of difference. Also what shocks are you running?
Caster mod. http://67-72chevytrucks.com/vboard/s...d.php?t=501241 Make it handle http://67-72chevytrucks.com/vboard/s...d.php?t=419251 Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-18-2015, 06:29 AM | #4 | |
the shocks came with the lowering kit i bought from brothers with the sway bars they look like they are a cheap generic shock I have always thought in the back of my head that a good quality coil over gas shock will change everything for the better |
09-18-2015, 06:31 AM | #5 | |
09-18-2015, 07:09 AM | #6 |
It may only have a degree or two in it. More does a lot for it. When I went from the kit KYB's to the Bell techs they were a huge improvement.
Jimmy
09-18-2015, 07:29 AM | #7 |
Most shops give you a report of what they set the camber/caster/toe settings to when they hand you your receipt.
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car) 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
09-18-2015, 07:49 AM | #8 |
09-18-2015, 08:39 AM | #9 |
it's most likely that gear box change
09-18-2015, 08:59 PM | #10 |
i found the print out from the alignment shop
left front has .1 degree camber right front has -.1 camber 1.0 caster (left side) 1.2 caster (rt side) .20 toe (left side) .18 toe (rt side) |
09-18-2015, 09:02 PM | #11 | |
right rear .1* camber left rear toe .39* right rear toe -.51* |
09-18-2015, 09:09 PM | #12 |
this is my truck her name is 8 ball
09-18-2015, 09:21 PM | #13 |
One foot in front of the other
You have a sway bar?
Sharp looking truck by the way |
09-18-2015, 09:26 PM | #14 |
09-19-2015, 12:22 PM | #15 | |
is it as easy as taking it back to the alignment shop and asking them to add some camber? |
09-19-2015, 12:27 PM | #16 |
Moderator
I started that Caster Mod this morning. Judging from what you have I will need it.
12-01-2015, 03:03 PM | #17 |
i had my shop add some caster and the truck is 90% better!
i drove 500 miles this past weekend and 80mph on the highway the truck drives dead straight and smooth! |
12-01-2015, 03:27 PM | #18 |
this is what we used
12-01-2015, 05:37 PM | #19 |
I cant tell by the picture if those are poly tires but if they are they are pretty good at following the grooves on concrete highways!! Just a thought
12-01-2015, 05:45 PM | #20 | |
i see Brothers offers upper and lower tubular control arms that allow for extra caster very pricey !!! i have lowered springs and drop spindles with stock control arms the tech was able to give me a huge change in the way it handles highway speeds by adding some caster alone to what i had. I have a little play in my idler arm too so I ordered a new one from summit when it arrives i will take it back and get it adjusted a little more when he does i will get him to give me another print out even with the play in the idler the truck has a totally different manner at speed now for the better! |
12-01-2015, 05:51 PM | #21 |
i also added a new set of monroe gas shocks for all 4 corners. the 2 back shocks were blown out so we moved the mounting location up to give it more room to travel.
12-12-2015, 10:18 AM | #22 |
now the truck drives perfect at all speeds right up to 80-85 it just settled right in with almost no effort or adjustment needed. I didn't want to push it faster just to be safe but it showed no signs of wobble or shimmy or shake totally rattle free I was so happy almost got misty when i noticed driving along easy at 35-40mph i can feel and hear a rubbing noise from the front end. is that what happens when you adjust it too far? Do i need to adjust it back some lil it stops rubbing not sure what is rubbing yet haven't had time to look deeper into it. I was thing of changing the upper control arms with the tubular ones from brothers
http://www.brotherstrucks.com/prodin...=UCA7200&qty=1 good idea or no? |
12-12-2015, 05:56 PM | #23 |
got a chance to put a lift under the front end this morning
found one of the sway bar ends was totally disconnected bolt worked it's way out along with the bushings. |
12-23-2015, 03:46 PM | #24 |
turns out to have been 2 different issues unrelated to each other
alignment is great truck holds the road really nice now rubbing noise was axle bearings and loose pinion bearings had her fully rebuilt and now she is nice and tight I have a Dana 60 with the post lock |
12-23-2015, 06:41 PM | #25 |
Thank you for following up on your thread and posting the resolution . Great way to close the loop on this so others can benefit.
