#101 |
Re: A 15 year old's project. Rusty 62 stepside
I can see the light!
This is a household light socket that the po put in. I put a 12 volt bulb in it and it works!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#102 |
That's so cool. Years ago I used to use a five watt bulb in household socket hooked to my CB radio. It would light up when you talk or modulate. Really neat way of testing the radio.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#103 |
Thanks, Sounds like a good idea
#104 |
First day of Christmas break, so I got busy. Built a 1bbl to 2bbl adaptor plate out of aluminum. Ported and polished the inside so it should flow pretty good. Then I got started on the linkage, the pic below is the pedal assembly after I flipped the arm so when I give it gas it pulls instead of pushing. Then I built a rod with bends that goes from the pedal arm to the carb. Here's a video: http://youtu.be/PU0i3WgsB0Y
#105 |
![]() ![]() Join Date: Jul 2002
Nice work on the linkage.
#106 |
![]() Join Date: Mar 2013
Looks good. That a carb off a gmc v6?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#107 |
Thanks guys. No the carb is a carter that I got for free from my dad's plymouth sine he went to a 4bbl.
#108 |
Made a cross member to put between the frame rails for the gas tank straps to bolt to. I will weld it in place later today.
#109 |
02
#110 |
Made some gas tank straps
#111 |
Cool, has the carter seemed to make a difference?
#112 |
Not a huge difference but defiantly helps
#113 |
Ok no pics right now but I finished all of the gas tank straps and mounts and bolted the tank in. Now it's time to pull it back off and get the bumper mounted so I know where to cut the hole for the gas filler.
#114 |
Started working on mounting the bumper. Built one of two brackets that will be welded to the bumper and bolt to a piece of angle iron that will go inside the frame rails. I made the holes oblong so that the height of the bumper can be adjusted.
#115 |
Number 2 is finished. The old set of files is sure getting a good workout
#116 |
I found this inside my radio
#117 |
Nice work on the bumper brackets. Did you really make the slots with a file?
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#118 |
X2, Nice work.
#119 |
Thanks guys. Yes I made them with a drill press, a hacksaw but mostly files. Took a while. Times like these when a cnc plasma cutter would come in handy
#120 |
Installed my Christmas present! Sun pro super tach 2.
I'm impressed with the quality, compatibility and look.
#121 |
Nice!
#122 |
Cool
#123 |
I am also 15. I am doing a 1964 k10. Go on youtube and check out "gibson63" He is doing a 1963 chevy. He does some of the best work i have seen. shows the steps in great detail. I would go and watch some of his videos. he is amazing.
#124 | |
#125 |
Hey! Great to see more young guys on here. I would like to see what your doing to your truck. Do you have a build thread? What are your plans? I've seen some of gibson63's videos and he does great work.
