Old 12-24-2015, 12:09 AM   #851
Iceburgh
Iceburgh's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Originally Posted by Advanced Design View Post
Thanks 99. Appreciate the explanation. Iceburgh tried the Alan Grove ac low mount and it wouldn't fit.
The Alan Grove lower would require pretty extensive mod of the frame, more so for me. I set my Motor back 3.5" that would cut deeper into the frame.
I tried just about everything out there. All had pros and cons. I decided on vps they are now making systems for lmc. But a little pricey
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 12-24-2015, 12:21 AM   #852
Iceburgh
Iceburgh's Avatar
AD...planning on putting a ls with carb in the 56 post I picked up. Looks like more room. Any problems when you put one in your 56?
1953 suburban build
Old 12-24-2015, 02:45 AM   #853
Advanced Design
Advanced Design's Avatar
The only real challenge was the oil pan because we did the swap before Holley brought out theirs. The centerlink really interferes there.
CPP small block stands and mount to the LS plate, Camaro exhaust manifolds, GMPP CTS-V accessory drive, KWIK for high mount Sanden (before Holley brackets) and it was pretty well bolt together. Lot more room under the hood than an AD truck. Before you go carb, maybe check out FITech. From what I've been seeing around here, it is a high quality and very affordable throttle body style injection system. Here is a build with one starting at post 392... http://67-72chevytrucks.com/vboard/s...605736&page=16
Be cool if you did a build thread under alternate tinkerings.
Accessory drives...I am following your lead on engine setback and looked at the front runner system you used. Yep pricey. Are you happy with the system? Do you remember how much room you have from front of block to radiator mounting flange? Are you still happy with the R and D radiator?
Advanced Design is offline   Reply With Quote
Old 12-24-2015, 01:11 PM   #854
99 to Life
99 to Life's Avatar
Side note, not to deter from the pullies, but that FItech looks awesome. I'll def be keeping them in mind.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-24-2015, 05:35 PM   #855
Advanced Design
99, it is an impressive looking system and way cheaper than Holley, Edelbrock, etc. There is another build on here where the owner purchased one for install though I haven't seen an update. Rodsgreen C10 is giving it a pretty good work out.
Ok, after standing around with a measuring stick and staring at it for awhile yesterday I did go ahead and move the engine back 1 1/2 inches. You know the drill...remove engine and transmission, cut tabs off of frame, grind smooth, reinstall to position and mark new tab for drilling, tack tab in, remove engine and trans so you can weld the tab, reinstall....folks that don't do this don't know how much work it takes. Heavy work keeps me alert too just in case the hydraulic cylinder on the engine hoist lets go.
Anyway, I now have and inch from the snout on the truck water pump to the back of the fan on the R and D radiator...assuming the dimensions they gave me are accurate. And I have 9 inches from the block face to the back of the fan which should leave room for a front drive system in the event I decide to go that way.
Based on advice from Iceburgh over on Youngrodders Burb build, I am leaving the recess cut outs open until I decide for certain what I am doing for an intake. His fuel rail on the new intake intersected the firewall. Bummer, especially since he has really nice paint.
Old 12-24-2015, 05:39 PM   #856
Advanced Design
Comparison, before set back.
Old 12-24-2015, 10:48 PM   #857
99 to Life
99 to Life's Avatar
nice progress and pics. I think if I have this problem, I'm going to cut out the firewall recess, widen it and reinstall, so it looks factory just much wider.
Old 12-24-2015, 11:42 PM   #858
Advanced Design
That would look better and I was considering, even had it laid out in tape. Trim the recess around the outside of the tape then add 8 inches to the center. It would be reinstalled about to where the outer tape marks are. I was kicking that idea around with a couple of friends and they pointed out it may take up space needed for the Vintage Air system.
So, rather than figure out if that would work spacewise under the dash or not, I just went this route.
Old 12-25-2015, 12:16 AM   #859
99 to Life
99 to Life's Avatar
haha great minds think alike, but you guys had me beat as I wasn't thinking that far ahead! I suppose you could get VA dimensions and make it up out of cardboard, put it in and figure out if it would interfere.
Old 12-25-2015, 12:49 AM   #860
Iceburgh
Iceburgh's Avatar
Agreed $1000 is a great price all others are in the $2200 range. Might go this route in the '56.
1953 suburban build
Old 12-25-2015, 12:58 AM   #861
Iceburgh
Iceburgh's Avatar
I like the R&D and prices are not bad.
If you look at what I have it works and it is compact. The alternator need a bracket made for it to give it more support. Easy fix. This came out after and about the same price and looks a little better I think.http://www.lmctruck.com/icatalog/ca/full.aspx?Page=79
Any way lots of trial and error or $$$ or both
1953 suburban build
Old 12-25-2015, 10:12 AM   #862
Advanced Design
Well, I saw that modification on one of the builds here so don't know that I have a great mind. VA use to have empty cases you could buy for mock up. I didn't want to wait and charged ahead.
Iceburgh, thanks for the link. This looks a little beefier than what is on their website and I like it is now available in black. While pricey, it is less than the VA package at @ $2,900.
My engine is back far enough now I think this will fit.
Old 12-25-2015, 03:29 PM   #863
BlueJeep
BlueJeep's Avatar
It will still fit. I just went out and looked at mine. I have lots of room between the VA and the dash, and I mounted mine so that it hugs the firewall pretty tight. You could easily bump it back another inch and have all the room you'd need to for your inset extension.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-25-2015, 07:38 PM   #864
Advanced Design
Thanks Bluejeep. Lotta problem solving in one of these builds.
Old 12-27-2015, 11:39 AM   #865
Advanced Design
There is one important element I didn't remember about accessory drive fitment when going through this.
Where is the back of the fan in the vertical plane in relation to the water pump pulley snout?
Looking at Tessone's build, I notice the back of the fan is above the snout. So, before moving the engine back into the firewall, I should have bought the radiator package and tried it to see. Of course I could pretend I really cleverly planned this so a front runner would fit.
99, maybe this will save you some work on yours.
Old 12-27-2015, 11:45 AM   #866
Advanced Design
Had a lot of fun with friends yesterday painting the frame on his 65 Pontiac wagon.
Old 12-27-2015, 11:48 AM   #867
Advanced Design
Engine and frame back in place. You can get so much more done with four guys than working along.
Old 12-27-2015, 12:13 PM   #868
Iceburgh
Iceburgh's Avatar
Mine is above it as well. One more thing to think about is where the air inlet for the intake will route. I wanted fresh air so it comes out and does a 90 through the fender. It fits between the alt and fan but it is a tight fit.
1953 suburban build
Old 12-27-2015, 12:18 PM   #869
Advanced Design
Yeah, that's why I did it......seriously, good point Jim. We were discussing that yesterday and going through inner fender in some fashion is what I want to do. Gotta check yours again and bluejeeps too.
One more family Christmas then hopefully good shop time rest of this week.
Old 12-27-2015, 09:20 PM   #870
Advanced Design
Couldn't find it on their website so I asked a technician friend and Googled around. The Corvette and Camaro compressors are variable displacement and that doesn't work well with the Vintage Air system. Supposedly will lead to failure of the compressor. Their system needs a fixed displacement compressor.
And I want a more solid answer so will keep looking.
Vintage Air has a description here why a variable compressor won't work.
http://www.vintageair.com/2015%20Cat...atalog%206.pdf
Old 12-27-2015, 11:26 PM   #871
youngrodder
youngrodder's Avatar
Keep at it Doug. Push past that last party and hit the garage. I have been making some progress the past few days.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-28-2015, 12:20 AM   #872
Advanced Design
Marc
On it....multi-tasking!
Old 12-28-2015, 12:10 PM   #873
99 to Life
99 to Life's Avatar
good pics, yeah def am getting radiator and headers for when I moch up engine. Ordering them soon.
Old 12-28-2015, 05:07 PM   #874
ptc
ptc's Avatar
What if you only went about half way up with the widening and fan it into the curve at the top? That could leave you enough room for both the VA and leave it looking oem.
Nice progress, I am at this point also and having everything you will be using in the final build sure helps alot!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 12-28-2015, 05:31 PM   #875
SparkyRnD
SparkyRnD's Avatar
been slowing going through the build thread per your PM, this is going to be one cool project!
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
