Old 12-14-2015, 11:26 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Gas door opinion
Guys I need some opinions on what gas door you would choose between these two, keep in mind the truck will have both upper and lower trim. I like the curved one as i havent seen it used before but the rectangle one might fit the shapes of the marker lights better. Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-14-2015, 11:35 PM   #2
Metaldoc
Metaldoc's Avatar
Re: Gas door opinion
I like the curved one, but your truck is raised so the rectangle could be a lower option to reach up to for refueling. I getting older so you to add in these factors and I'm not that tall.
Derek
Metaldoc is offline   Reply With Quote
Old 12-14-2015, 11:55 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Neither. 88-98 Silverado/Tahoe/burb.
Looks excellent on fleets too.
If I had to pick from the above... The yellow one.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-15-2015, 12:05 AM   #4
71blksuper4x4
SWB 4x4 Collector
Put one on one of my first trucks. Didn't look bad, but trying something new.
TREVOR
Old 12-15-2015, 12:06 AM   #5
'68 Newtricks
'68 Newtricks's Avatar
The one you call "curved" is my choice. I fits the lines of the truck better. The square one would fit a 60-66 or 73+ better IMO
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 12-15-2015, 12:39 AM   #6
CG
BlahBlahBlah
I like em both. But to me ... the gold one might edge it out a little because the corners match the edges and angles on the truck better.
Old 12-15-2015, 12:49 AM   #7
jocko
jocko's Avatar
rectangle on a flat surface, by far. I think it would look better fwd of wheelwell, in the 73+ stock location, but I'm assuming that's not gonna work based on tank location. Another option is the marker light filler approach. I think the curved surface approach will detract from the curved body line in that location personally. All look good though.
Old 12-15-2015, 09:32 AM   #8
7tee
7tee's Avatar
Now that is nice jocko...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 12-15-2015, 09:48 AM   #9
javelinmania
Take a look at the following after market door.
http://www.yogisinc.com/index.cfm/pa...d/prd13954.htm.
They have a template that you cut out and match against your truck and there is a spot that is a match. I don't know if it will fit between the moldings - you will have to check.
http://www.haganauto.com/v/vspfiles/...20template.pdf
javelinmania is offline   Reply With Quote
Old 12-27-2015, 10:45 PM   #10
MAC71
MAC71's Avatar
I like the curved one. What did it come off of?
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 12-27-2015, 11:16 PM   #11
71blksuper4x4
SWB 4x4 Collector
IH travel-all, here is was mocked in before pulling out my low spots.
TREVOR
Old 12-27-2015, 11:51 PM   #12
chewychevy67
I like it!
chewychevy67 is offline   Reply With Quote
Old 12-28-2015, 01:28 PM   #13
Nitis
Nitis's Avatar
It looks like it's higher on the body than I envisioned mine would be is that because of the curves you had to work with or is there a benefit to filling the tank?
You running a square body blazer tank?
Nitis is offline   Reply With Quote
Old 12-28-2015, 01:50 PM   #14
67ChevyRedneck
Great job on the install!
Jesse James
Project "On a Dime"
Old 12-28-2015, 02:29 PM   #15
davepl
davepl's Avatar
It had to go high in order to intersect the curve, because the door was curved, and the door was curved because sometimes its cool to do it the hard way - with a curved door.
Just FYI, when I did some research on keeping my triple tanks I found tha Ford vans had a dual tank option with mirrored doors, so you can harvest a door from each side and they match. Wouldn't be curved though, and only important if you're doing both sides.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-28-2015, 02:37 PM   #16
Nitis
Nitis's Avatar
Wouldn't the square bodies with saddle tanks also have mirrored doors? Just a thought.
Old 12-28-2015, 04:57 PM   #17
haysonj
haysonj's Avatar
Just to throw it in the mix here is a 95 door in my 69 fleetside. I didn't care for the square ones at the time I did mine.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-28-2015, 07:42 PM   #18
71blksuper4x4
SWB 4x4 Collector
Nitis, it's because I had to lower my bed cross members about 2" on my bed so that my cab matched my bed in height. My truck is on a c30 c&c chassis which is completely different from the c30 and down frames. With the 2" drop, the filler door would have been almost straight into my tank. Rather than having to spend 20 min clicking on and off at the pump, I went with this door, which I had never seen used before. Should be able to still use the blazer fuel neck from our generations and yes, I am using a modified 31 gallon 73-91 blazer tank.
TREVOR
Old 12-28-2015, 09:51 PM   #19
71blksuper4x4
SWB 4x4 Collector
Paint dried....pre body work.
TREVOR
Old 12-28-2015, 09:53 PM   #20
70LonghornCST
Moderator
70LonghornCST's Avatar
Nice work!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-29-2015, 01:03 PM   #21
Not that one, the other one!
Lookin' good
Old 12-30-2015, 12:48 AM   #22
CG
BlahBlahBlah
Turned out great, I really like it. You couldn't really go wrong either way.
