Old 12-27-2015, 10:35 PM   #1
61K10
61K10's Avatar
New U bolts
front axle u-bolts--anything on the threads? No lock washers so?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-28-2015, 12:22 AM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: New U bolts
I used flat washers and nylon lock nuts. That was what came with the new set of U-bolts on my lift when I bought it. Originally had flat washers and standard nuts.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-28-2015, 12:22 AM   #3
obijuan
Re: New U bolts
Nothing on the threads and they should have the tall ubolts nuts and flat washer or something better. Use appropriate torque and they will stretch and stay tight.
obijuan is offline   Reply With Quote
Old 12-28-2015, 01:36 AM   #4
kwmech
Re: New U bolts
Ny-locs not really necessary. If you use a standard u-bolt the threads should be rolled, the hi-nut will be a cut thread, grade 8 flat washer under the nut. Light oil on the threads and torqued properly and re-torqued after some miles.
Old 12-28-2015, 12:05 PM   #5
61K10
61K10's Avatar
Re: New U bolts
thanks guys--u-bolts have the tall nuts and thick washers. From WFO
1961 chevy K10
