Closed Thread
Old 12-27-2015, 08:48 PM   #1951
jbgroby
jbgroby's Avatar
Re: What did you do to your truck today part III
I figured out how rig up some temporary header extensions to keep the hot exhaust from burning off the engine paint from the block. I'll run this until I get to the muffler shop to get the real pipes mounted up.
jbgroby is offline
Old 12-27-2015, 08:48 PM   #1952
schpeen
schpeen's Avatar
That came out looking really good schpeen!
thanks, i think i will sand it down and stain to match the floor
schpeen is offline
Old 12-28-2015, 07:52 PM   #1953
OldChevy61
OldChevy61's Avatar
Bolted the bell housing ,motor mounts, and perches to the block. Got the location for the perches marked and holes drilled. Now I need longer bolts,lol. Block is freed up now to get this engine together now.
OldChevy61 is offline
Old 12-29-2015, 01:19 AM   #1954
Heater63
Heater63's Avatar
This took much longer than I ever thought it would, but my brother and I finally got my cab in paint. We spent countless hours over a couple of years on weekends. All done in our garages, but at least we had access to a state of the art booth to spray.
292 + TKO500
Heater63 is offline
Old 12-29-2015, 09:04 AM   #1955
jbgroby
jbgroby's Avatar
THAT looks great! The green color really pops.
jbgroby is offline
Old 12-29-2015, 10:21 AM   #1956
The Rocknrod
Moderator
The Rocknrod's Avatar
Denton Texas Lookin Good.
The Rocknrod is offline
Old 12-29-2015, 11:26 AM   #1957
TJ's Chevy
TJ's Chevy's Avatar
Looks good!
TJ's Chevy is offline
Old 12-29-2015, 12:30 PM   #1958
jturner18
Took 2 hours to scrape (not finished) off one side of the front end. 50 years of buildup. Hey, at least it's not rusted. Lol
jturner18 is offline
Old 12-29-2015, 03:36 PM   #1959
Grizz1963
Grizz1963's Avatar
With Martin's extra hands my cross member is now bolted in, and the drivers side LCA bolted in. The passenger side needs its ball joint to be removed as the LCA is damaged and will be replaced by the one that came from Paul "NevEno" once I push in the ball joint.
And an even more awkward job done as it needed a spare hand to lift the trailing arms in via the jack and getting the bolts through and buttoned up.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 12-29-2015, 04:26 PM   #1960
OldChevy61
OldChevy61's Avatar
Very nice work. Looks like the same green I have picked out. Single stage paint or base/clear? How long before you paint the rest of the truck?
Old 12-29-2015, 07:13 PM   #1961
OldChevy61
OldChevy61's Avatar
Pulled the glovebox, heater box, radio, and steering column out. Pedals and wiring tomorrow.
Old 12-30-2015, 12:10 AM   #1962
Heater63
Heater63's Avatar
It's a Sikkens number, it doesn't have a name. The interior is single stage. The exterior is base/clear.
Lizard skin noise reducer sprayed on the floor, Sikkens OTO (like lizardskin) on the cab underside.
Next is steering column, autowire harness, dash, doors. It will be months before the other panels/pieces are ready for paint.
Good luck with yours!
292 + TKO500
Heater63 is offline
Old 12-30-2015, 12:42 PM   #1963
forestb
forestb's Avatar
visited the truck at the paint shop
forestb is offline
Old 12-31-2015, 08:09 PM   #1964
OldChevy61
OldChevy61's Avatar
Got the engine stands bolted in and painted. Gonna start engine assembly tomorrow.
Old 01-01-2016, 03:24 PM   #1965
mjh1965
mjh1965's Avatar
Well I needed to get a gearbox crossmember , as I have changed from straight 6 manual to a V8 with a TH350 auto box .
The trouble with being in the UK the cost of shipping is far to expensive for such a heavy item . So £5 or $7.50 worth of steel from a local scrap yard . I decided to make one
Well I managed to get my crossmember made today .
This is with the gearbox mount in place
What I did find was the C section I used on the ends is an inch shorter than the chassis rails , so instead of cutting and changing it . I decided that by using two half inch spacers , I have the option of raising the crossmember , depending were the spacers are placed . Tomorrow I plan on checking the clearance with the exhaust to see if I need to put some notches in , if it fits I will drill the holes and get it painted .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 01-01-2016, 03:39 PM   #1966
LT1 Burb
LT1 Burb's Avatar
Nice job
LT1 Burb is offline
Old 01-01-2016, 03:55 PM   #1967
jtrichard
Originally Posted by Turtleman View Post
I thought I'd start looking for a new set of brake rotors
Why rush into things you still have 3 others ...... Brakes are so over rated LOL
jtrichard is offline
Old 01-01-2016, 04:19 PM   #1968
Backpayne
Finished completely redoing my front drums. Wheel cylinder on right was bad (locked up on me while driving nearly making me mess my britches) so thought it would be best to replace everything: drums, wheel cylinders, springs, bearings, shoes, and hoses. First time I had ever worked on drum brakes and packed bearings. SloMoe now drives smooth and stops smooth!
Backpayne is offline
Old 01-01-2016, 05:58 PM   #1969
OldChevy61
OldChevy61's Avatar
Got the bottom end of the Heart together.
Old 01-01-2016, 11:37 PM   #1970
jbgroby
jbgroby's Avatar
Mounted the Emergency flasher in a spare hole on the lower dash
jbgroby is offline
Old 01-02-2016, 12:26 AM   #1971
TJ's Chevy
TJ's Chevy's Avatar
I pressure washed my 64 GMC and installed a ball and safety chain mounts. Firewall is white again and most of the engine paint is showing now.
Old 01-02-2016, 10:13 PM   #1972
derail
derail's Avatar
I did the same thing. It just looked like the natural spot for it since there wasn't a choke any longer.
derail is offline
Old 01-02-2016, 10:47 PM   #1973
oldies1938
I'm ready for El NINO
oldies1938 is offline
Old 01-03-2016, 01:00 AM   #1974
nail pounder
nail pounder's Avatar
I put the Chevy decals on my grill. Then I was looking at some mud I thought I should hose off, when I noticed some wire up in my passenger side wheel well, wonder how long those keys have been there.
nail pounder is offline
Old 01-03-2016, 11:33 AM   #1975
jbgroby
jbgroby's Avatar
Ain't that a hoot.
jbgroby is offline
Closed Thread
