Old 02-26-2004, 11:10 PM   #1
Robo_bot
Robo_bot's Avatar
Exclamation Mounting Front sway bar
Does anybody have any tutorials or pics of how to mount a front sway bar on a 67 -72 chevy frame????
Robo_bot is offline   Reply With Quote
Old 02-26-2004, 11:17 PM   #2
adamls
Gotta Startem Early
adamls's Avatar
Any sway bar from a 67 through the early 90's (I think) will work. The bar mounts to bothe frame rails and to the lower A-arms on both sides. If you have acces to a junkyard you can look a the setup and get a sway bar pretty cheap. Any vendor here can provide the brakcets.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 02-26-2004, 11:18 PM   #3
Robo_bot
Robo_bot's Avatar
i have the sway bar already im just trying to figure out where exactly to mount it hey thanx for the help
Old 02-26-2004, 11:27 PM   #4
adamls
Gotta Startem Early
adamls's Avatar
Sorry, there are two holes on the lower a-arm about 3-4 inces from the shaft. The bar will go on top of the arm between the bolts. If you put the bar in place you will see where the holes are in the frame. One hole will problably have a rivet in it if your truck did not originally come with a sway bar. Drill it out and replace with a bolt.
Old 02-26-2004, 11:28 PM   #5
Robo_bot
Robo_bot's Avatar
cool thanx bud
Old 02-26-2004, 11:57 PM   #6
72c10step
WHYBYNU when old will do?
72c10step's Avatar
go here
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
