Old 12-29-2015, 10:08 PM   #1
Super_Dave
Super_Dave's Avatar
Wiper question...
My Forrest Gump question to end the year with...
I have noticed that my wipers really slow down when I am idling and work great once I get the rpm's up. So, not being that well versed in the overall wiper system, it seems it runs, to some extent, on a vacuum of some sort, rather than 100% electrical.
If my assumption is correct, can the wipers be made to work only on electrical and eliminate the vacuum?
Forrest Gump
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 12-29-2015, 10:25 PM   #2
ray_mcavoy
Re: Wiper question...
The wipers in these trucks are 100% electric.
What you are experiencing is most likely a voltage drop due to the alternator not producing as much power at lower engine speeds. You can confirm this by hooking up a voltmeter if your truck doesn't have one already. If that's the case you'll want to give the charging system a thorough check and repair or upgrade as necessary.
ray_mcavoy is offline   Reply With Quote
Old 12-29-2015, 10:33 PM   #3
4 Wheelin Fudpucker
4 Wheelin Fudpucker's Avatar
Last vacuum wipers were in 72.
I also ran another ground wire to the wiper motor
Happy as a pig in mud
4 Wheelin Fudpucker is offline   Reply With Quote
Old 12-30-2015, 09:09 AM   #4
gmachinz
I've had good experiences running the main motor power through a relay and powering the relay off the main firewall junction along with a better case grounding wire too.
gmachinz is offline   Reply With Quote
Old 12-30-2015, 05:12 PM   #5
Super_Dave
Super_Dave's Avatar
Thanks guys.
My mama always said working on these trucks is like a box of chocolates... you never know what you're gonna to get.
Forrest
Old 12-30-2015, 10:03 PM   #6
franken
If you go out and open the box (hood), and look at the chocolates (wiper motor), then extrapolate next time, we can call you Dave in the future...
We're all Forrest over and over. I find that when I'm sure that something isn't the problem, and don't need to look at that bit it's the time to look at that again on the next pass. Or, when the problem isn't solved, its probably the part you're sure isn't the problem.
