Old 10-16-2015, 12:19 AM   #726
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
A couple more pics.
oldman3 is offline   Reply With Quote
Old 10-16-2015, 08:45 AM   #727
Kim57
Kim57's Avatar
Looks like a nice little event.
Real nice of you guys to do that for the people there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-16-2015, 02:00 PM   #728
Advanced Design
Advanced Design's Avatar
Really a nice way to share the cars and have fun with people. Looks like a great event!
Advanced Design is offline   Reply With Quote
Old 10-16-2015, 04:40 PM   #729
oldman3
oldman3's Avatar
Kim
Thanks guys. We had as much fun as the residents. Thinking about doing this annually, one day I might be on the other end, and would enjoy it...Jim
Old 10-16-2015, 07:59 PM   #730
Advanced Design
Great idea! After seeing your pictures, Cindy suggested maybe we could do this too so we are going to try to copy your idea. Hope you don't mind Jim.
Old 10-16-2015, 11:52 PM   #731
oldman3
oldman3's Avatar
Doug,
I'm sure someone did this before me. Hope you can get it arranged, I'm sure you will enjoy as much as we did...Jim
Old 12-30-2015, 11:23 PM   #732
oldman3
oldman3's Avatar
Hey guys, instead of pics and cruise etc., this update is on another change I've wanted to do for a long time, but could never find a way to do it. You know the old say "these things are never done" (meaning our rides). When I was building my truck I set it up with a 78 Chevy Caprice column with the stock steering wheel. Well, when I installed the La Carre wheel and adapter it moved the wheel toward the driver. Everything was painted and done, so I just let it go, driving was fine, but I always wanted a little move arm room.
12 yrs later I found an ad from Southern Rods about a new shorty adapter. Called them up, and it sounds like they have what I need, so I order it. Long story short it works great. (Oh, my son Mark did the work, I did the hard part and took pics)
Here's the ink to the part http://www.southernrods.com/steering...y-adapter.html
Pic 1 typical 2-5/16" adapter, notice the distance from wheel to turn signal arm.
Pic 2 Flat horn button on the wheel
Pic 3 The new shorty adapter with new bolts, etc.
Pic 4 Looking at old adapter before removing (notice how far down the shaft is inside the adapter).
Pic 5 New shorty adapter setting on shaft, not tightened down yet. (Notice how hight the shaft is above the adapter)
Old 12-30-2015, 11:41 PM   #733
oldman3
oldman3's Avatar
Pic 1 You still need to use the old wheel ring with the beveled holes to hold wheel to adapter, just like the old one. (use the new bolts that come with the new adapter they are smaller).
Pic 2 Notice distance from wheel to turn signal arm.
Pic 3 If anything negative about the install is the higher horn button location, but is is necessary to cover the shaft from steering column.
Pic 4 New adapter on column, old one below.
I thought that if anyone needs 2" less on their column length with the wheel installed, this is a good way to go. Isn't cheap, but takes care of the problem...Jim
Old 12-30-2015, 11:46 PM   #734
Indian113
Indian113's Avatar
Jim, does having the turn signal stalk that close to the wheel hurt anything? Looks good but I've always liked your truck and don't see the Flaws you see.
Indian113 is offline   Reply With Quote
Old 12-31-2015, 12:10 AM   #735
oldman3
oldman3's Avatar
Hey Ray, Thanks for checking it out. No the turn signal arm has enough room, but I really noticed how close it was when I took it for a drive and used it a couple time. Wasn't really a flaw just something that bothered me (ha ha) OCD, OCDC, ADHD whatever that stuff called ...Jim
Old 12-31-2015, 01:19 AM   #736
Scott2
Thanks for the info on this. I'm sure I will need one shortly.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 12-31-2015, 04:51 AM   #737
RockinKees
RockinKees's Avatar
Looks good Jim!
I'm sure you notice that 2 inch difference
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-31-2015, 08:41 AM   #738
Advanced Design
Nice modification Jim.
Ididit came out with a shorty adapter a few years ago and they do mention to watch the clearance to turn signal stalk and shift lever. Guess that is the only downside for a little more arm room it is worth it.
http://www.ididitinc.com/accessories...daptors_Acc-16
Thanks for sharing.
Old 12-31-2015, 09:57 AM   #739
oldman3
oldman3's Avatar
Your welcome, hope it works.
Originally Posted by RockinKees View Post
Looks good Jim!
Thanks Kees, Yes it makes a difference, much better...Jim
Old 12-31-2015, 10:01 AM   #740
oldman3
oldman3's Avatar
Thanks for sharing.
Thanks Doug. I can't believe you found that so easy. I checked their site several times over the years and never saw that adapter. Just goes to show you. If it becomes necessary I can always, bend, my signal arm a little, but it's good for now...Jim
Old 12-31-2015, 12:41 PM   #741
solidaxel
solidaxel's Avatar
I had the same problem with the 55 so I just shortened it a bit and re threaded it.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-31-2015, 02:58 PM   #742
oldman3
oldman3's Avatar
Good ideal, thanks, but mine is the flat type that gets a screw...Jim
After checking, mine is a screw in style, sorry...Jim
Old 12-31-2015, 04:32 PM   #743
solidaxel
solidaxel's Avatar
Does the knob have a 1/4-20 on that end?
LS 3 4L70E
Old 12-31-2015, 05:17 PM   #744
joedoh
joedoh's Avatar
thats a great mod, I never knew someone made a shorter one. I had to put a LONGER one on my 47, the billet one wouldnt let me switch highbeams on and off with the lecarra wheel and the 99 column. I had to buy a 70s stock black wrinkle coat lecarra hub that was slightly longer.
if you dont want to make it shorter and your knuckles are banging it in turns (that was also a problem on mine) you could always put it in a vice and put a technical bend in it.
Old 12-31-2015, 06:11 PM   #745
oldman3
oldman3's Avatar
Solidaxel, after you question I went and checked my turn signal arm. I was wrong it is the screw in style. The knob end is a 1/4-28 fine thread. This arm also is the headlight dimmer switch and it works without hitting the wheel. Sorry for the prior wrong info...Jim
joedoh, right now the headlight dimmer switch works fine. No problem with the knuckles hitting, but later I might bend if necessary...Jim
Old 02-07-2016, 05:58 PM   #746
BossH0G
BossH0G's Avatar
Do the planes land there and eat? Or do the pilots land there and eat?
BossH0G is offline   Reply With Quote
Old 02-08-2016, 09:39 AM   #747
lower50's
lower50's's Avatar
I think it's ACDC
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-31-2016, 10:30 PM   #748
oldman3
oldman3's Avatar
Well guys it's that time of year again, my yearly trip to Springfield for the Mid
America Nats. As per my usual, up and back on Friday, up Saturday stay the night and back on Sunday, with a little over 500 miles total. Didn't take any pics on Friday, Mark and I were buying things we need for the shop and customers rides. Did hit some hard rain returning home on Friday, but rest of week-end was great. Saturday at the Nats was the best time I've had in years, will talk about it later in the update.
Old 05-31-2016, 10:41 PM   #749
oldman3
oldman3's Avatar
Pic 1 Talents Rod Shop always brings a ride each year to show their work. This was right in front of where we were parked.
Pic 2 another view
Pic 3 interior shot
Pic 4 engine
This was one of the rides for the Winners Circle
Old 05-31-2016, 10:47 PM   #750
oldman3
oldman3's Avatar
Pic 1 This is where we were parked, Jimbo's 67, Joe's 34 pickup.
Pic 2 Ed's Olds Cutlass, Glenn's 39, Marshalls 34, and the empty spot is where I was parked.
