Old 12-30-2015, 10:13 PM   #1
1978chev
suspension question
hey guys i have a 69 c10 just installed a complete suspension system from cpp i got the tubular control arms upper and lower 4.5 drop in front with spindles and springs have a total of 7in drop in rear 5in springs 2in blocks with shock relocaters in rear new shocks all the way around and front and rear sway bars and the adjustable pan hard bar
i have 20's front and rear 245/40 on front and 275/40 on rear
my problem is on most roads the truck is very twitchy i have aligned it a couple times.front end is tight has all new tie rods no play at all (a little in gearbox but my daily driver has more play than this thing) the alignment is good camber is -0.2deg on both sides and caster is around 4.5 deg posative thrust angle is 0.17 any one have any suggestions
1978chev is offline   Reply With Quote
Old 12-31-2015, 12:20 AM   #2
oldman3
oldman3's Avatar
Re: suspension question
I'm not an alignment person, but I've always been told you want has much positive caster as you can get, Not degative. Will run straighter down the road. Maybe someone that knows more than me will chime in...Jim
oldman3 is offline   Reply With Quote
Old 12-31-2015, 02:36 PM   #3
tinydb84
tinydb84's Avatar
What is your toe? If it is in it will be a bit twitchy.
David
Instagram: myfabguy
Old 12-31-2015, 08:20 PM   #4
1978chev
Toe is +0.05 deg
Drove it around today I think it might just be some of the roads around here. We have lots of semi trucks so the roads have pretty big road crowns. Took it on a nice new road and it drove pretty good
