12-20-2014, 07:09 PM | #1 |
Switched Ignition wire
I need a switched ignition source up by the drivers side firewall in the engine compartment. I'm looking at the wiring diagrams now, but if anyone has a source they typically use and can let me know, that would be great.
Thanks!
'84 K20 350/465/208 |
12-20-2014, 07:11 PM | #2 |
Re: Switched Ignition wire
Maybe the pink wire feeding the distributor?
12-07-2015, 03:58 AM | #3 |
Collector of Projects
I need a key-on switched power feed in my engine bay as well. Any updates? Suggestions.... PICTURES?
12-07-2015, 08:33 AM | #4 |
I have a painless harness installed, so I had some open wires I could use. I used the power wire to my fuel pump. Just check your fuse block and see what powers up on key
http://67-72chevytrucks.com/vboard/s...d.php?t=685572
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
12-29-2015, 06:05 PM | #5 | |
I know the pieces fit
12-29-2015, 06:20 PM | #6 |
Kid's Mechanic
12-29-2015, 06:57 PM | #7 |
I have those, just curious about the proper way to make a permanent connection. I can put a male terminal on the end of the wire and push it into the clip in one of the IGN spots, but that seems hokey.
12-29-2015, 07:08 PM | #8 |
This is the type of connector GM used to factory wire accessories that plug into the "IGN" receptacles on the 78+ fuse boxes.
They plug in to the front of the fuse box. And unlike a generic male blade terminal, the connector's plastic shell has a latch to hold it securely in place. Here's one source for them --> http://www.repairconnector.com/gm-ig...ock-tap-clear/ |
12-29-2015, 07:16 PM | #9 |
I just use generic female blade terminals. Done.
Rich Weyand 1978 K10 RCSB DD. |
12-29-2015, 07:22 PM | #10 | |
12-29-2015, 07:36 PM | #11 | |
I should probably mention that those connectors are keyed so they will only plug into the "IGN" receptacles. If you need to plug into other receptacles on the fuse box, there are similar looking connectors specifically keyed for them as well. For example, here's the one that plugs into the "BAT" receptacle for constant power --> http://www.repairconnector.com/gm-fu...wer-always-on/ |
12-29-2015, 08:17 PM | #12 | |
12-29-2015, 08:46 PM | #13 | |
The BAT receptacles are protected by the 20A "HORN / DOME" fuse. I believe many years have the cigarette lighter wired to this circuit as well. And the optional clock or digital stereo (if equipped) is also plugged into the BAT receptacle. So just keep in mind these other loads that may already be on this circuit when you consider adding more. |
12-30-2015, 12:46 AM | #14 | |
No doubt! |
12-30-2015, 12:59 AM | #15 |
I see all the info is pointing to sources in the cab of the truck. But is there any switched power already in the engine bay besides the HEI?
12-30-2015, 02:28 AM | #16 |
The YEL/BLK wires on the wiper motor and washer solenoid should be hot with the ignition.
12-30-2015, 09:13 AM | #17 |
At the firewall bulkhead you can also tap into your (for 1981-up anyway) pink w/blk stripe 14ga wire. This is the switched 12V source to one side of your oil pressure switch for the electric choke.
12-31-2015, 08:35 PM | #18 | |
Carefull what you tap in the CUCV and use a meter, not a test light. There are 24v sources in the CUCV fuse block. I'll send you a good CUCV Fuse Block Aid that explains what is controlled by the Ign, B/O and Service Lamp Switchs,
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
