Old 01-01-2016, 10:41 AM   #1
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
I uses KBS on the front of the chassis a year ago. At this point is seems like the least labor intensive and cheapest option.
https://www.kbs-coatings.com/frame-coater-kit.html
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-01-2016, 11:56 AM   #2
youngrodder
youngrodder's Avatar
The Frame looks great. You mention the holes in the frame. Once you remove the other factory stuff to install the PB stuff it creates even more holes....I will only fill the ones that you see. Some are covered by the PB stuff.
I liked having my frame chemically stripped (doesn't sound like it is an option for you based on where you live) because it got the frame super clean and doesn't leave the metal surface etched like when you sand blast.
I like your accounting sheet on the $$ spent. I do that kind of stuff myself.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
