Old 12-31-2015, 01:33 AM   #1
swamp rat
swamp rat's Avatar
Aftermarket Flexplate cover
I'm wanting to buy an aftermarket TH350 flexplate cover as my stocker is getting pretty worn out. finding a number of different ones on Summett, Jegs, Flea bay and amazon but also reading in the reviews that some have fitment issues.
If you have bought an aftermarket unit for a TH350 could you tell me which one and if you were happy with it or what modifications you had to do to make it fit?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-31-2015, 02:20 AM   #2
TexasLS1
TexasLS1's Avatar
Re: Aftermarket Flexplate cover
I wish I could help on this, but I've bought 2 that I could not get to fit. I'm hoping someone has an answer for us!
TexasLS1 is offline   Reply With Quote
Old 12-31-2015, 04:39 PM   #3
swamp rat
swamp rat's Avatar
Bump, anyone else?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-31-2015, 04:40 PM   #4
swamp rat
swamp rat's Avatar
Can you tell me what brand or part numbers you bought so i know to steer away from them??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-31-2015, 10:43 PM   #5
TexasLS1
TexasLS1's Avatar
I can't help with part numbers unfortunately. The first one I bought was a chrome aftermarket cover that I bought from a guy on Craigslist. He said he bought it from Summit and claimed he had it installed on his 69 C10. He had trimmed it near the starter, but I could not get the holes to line up, and the flywheel contacted the inside of the cover.
The 2nd one I bought from a member parting out a truck here, on the parts board. It was supposedly an OE factory steel piece (it did appear to be), but I still had the same issue with holes not lining up and it contacting flywheel. Since then I've been afraid to buy another one lol!! I must be doing something wrong, or maybe I keep getting covers intended for the TH400?
Old 01-01-2016, 01:20 PM   #6
OregonNed
OregonNed's Avatar
I'd like to know too. My truck came without one
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 01-01-2016, 04:22 PM   #7
cdowns
cdowns's Avatar
if holes don't line up I use what is called an electric drill and make appropriate adjustments then if it's hittin somewhere I use what is called a dermal tool to make it not hit anything
Old 01-01-2016, 04:34 PM   #8
swamp rat
swamp rat's Avatar
Well smart ass i was reading reviews about how some of these are twisted badly coming out of the hydropress and no matter how much they tried to straighten then they ended up hitting the flex plate, just wanting to avoid that and not have to do a return ship, is that too much to ask? i really would not want to use a dremel ( NOT DERMAL ) to grind a hole in the body of the thing to clear flex plate teeth, kinda defeats the purpose.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-01-2016, 08:42 PM   #9
cdowns
cdowns's Avatar
well since you don't have the skill to fabricate a fix it might b cost effective for you to hire a professional to do it fer you
Old 01-01-2016, 09:01 PM   #10
TexasLS1
TexasLS1's Avatar
Shots fired, shots fired!! Everyone stand down!! Lol
We're just trying to find out if there's a piece that is a direct replacement, when there's a known, common issue with the replacement parts not fitting properly.
Since I've had no luck with the ones I've picked up, I've figured my only options are to modify and shim to get one on, or just go without one.
Would be nice to hear from anyone who's found one that fits correctly (if such a one exists...)
Old 01-01-2016, 09:21 PM   #11
swamp rat
swamp rat's Avatar
Yet again you let your ignorance fly, go get a life
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-01-2016, 10:54 PM   #12
9teen69
9teen69's Avatar
I had the same problem as TexasLS1 with this one from Summit...no good.
SUM-G3883B
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 01-02-2016, 05:09 AM   #13
toolboxchev
Interesting, Very Interesting...
toolboxchev is offline   Reply With Quote
Old 01-02-2016, 06:31 AM   #14
swamp rat
swamp rat's Avatar
SUM-G3883B
Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-02-2016, 08:59 AM   #15
BugzC10
BugzC10's Avatar
Do you think they are still available through a GM dealer? Mine is the thick plastic one and fits great. I assume it is OEM, but maybe not. Just thinking the TH350 was used on a lot of vehicles and the dealer still might carry them.
Edit: I checked RockAuto....nada.
1970 C10 Short Stepper with 71/72 front clip….gave to my son in Goodyear AZ.
BugzC10 is offline   Reply With Quote
Old 01-02-2016, 12:36 PM   #16
Zane M
I don't have any experience with the aftermarket choices, I personally would just go grab a factory piece from the wrecking yard.
Zane M is offline   Reply With Quote
Old 01-02-2016, 01:13 PM   #17
bigbadchev72
People know me
bigbadchev72's Avatar
I just went up to my local transmission shop and bought a new locking dipstick, tube, GM cover and a shifter lever for my TH350 the cover fit no problems at all with the 164 tooth flexplate and bolted up no modifications
Google of the factory part number gm 14038632 shows it availible here
http://www.gmpartsdirect.com/oe-gm/14038632
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 01-02-2016, 03:01 PM   #18
BugzC10
BugzC10's Avatar
http://www.gmpartsdirect.com/oe-gm/14038632[/QUOTE]
That part number is also available on Amazon and eBay.
Old 01-04-2016, 06:01 AM   #19
swamp rat
swamp rat's Avatar
Thanks for the information! I went to gm parts direct and they wanted more for shipping than for the part.. went to Flea bay and ordered it with free shipping but slightly higher price for the part, close enough..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-04-2016, 06:02 AM   #20
swamp rat
swamp rat's Avatar
That part number is also available on Amazon and eBay.[/QUOTE]
Thanks Bugz, ordered thru Flea bay.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-04-2016, 07:54 AM   #21
I think anyone who can grab a wrench has the skill to install a flex-plate cover, if they've never put a part on in their life. There is only one flex-plate cover on a vehicle and only one TH350 case. There is no reason a flex-plate cover made for a TH350 shouldn't fit on all TH350s in any vehicle. GM ones do. The issue here is the aftermarket part is crap and the tool required to fix it is a trash can
Old 01-04-2016, 01:22 PM   #22
swamp rat
swamp rat's Avatar
Yea i get it and i'm fully capable if much more than installing a flexplate cover, did i ever say i had not done it before?? A wrench would be a pita in my opinion, i'll stick to a long extension and socket.
If ya read my posts you will see i just wanted to buy a possibly better replacement cover after reading reviews that some of the aftermarket stuff was crap, that and figuring a stock replacement was no longer available..
The only reason one stock GM TH350 cover may not work with another GM TH350 is when ya got a standard case and a K case. Knowing now that an original GM part number is available for the cover its a non issue.
As i just posted i went ahead and ordered the number that was just posted. End of discussion.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-04-2016, 08:40 PM   #23
I read the entire thread. Who pissed in your Cheerios? You should know that when someone quotes a post, then posts a reply, it means they are responding to that post. Oh wait, you just quoted me because you were responding to me, so you already knew that. Just Chill out then...sheesh! BTW, are you saying you just grab and turn the extension and socket with your hand or do you fasten that to a WRENCH?
Old 01-17-2016, 12:52 AM   #24
9teen69
9teen69's Avatar
Swamp Rat or bigbadchev72- How does it fit?
