Old 01-01-2016, 08:39 PM   #851
99 to Life
99 to Life's Avatar
Re: 1949 Chevy 3600 into a daily driver
coach, I'm sure you don't want your thread clogged up with pages of what to coat your frame with, there is tons of info out there. Would I say the best option is pay to blast and then epoxy primer. YES, but..... would I also say buy all your tools from America? YES is that feasible NO. for you its different because this is a family truck and its a forever truck. So if you want to ball out by all means do so. But like a lot of guys on here some cuts need to be made. I'v personally never heard bad things about rust inhibiting coatings, esp when top coated.
Flap discs are going to be your best option IMO if you're not blasting the frame. that and a cut off wheel. You are not going to get the surface as good as blasting, but its the next best thing, which is sometimes the pill you have to swallow on building a truck.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-01-2016, 10:38 PM   #852
Coach529
Coach529's Avatar
Don't worry about clogging this thread up.....I love these discussions. I always end up learning something.
It is a constant struggle. Budget vs wants vs what is best etc.
Since this is a forever truck I want it done RIGHT.....but ultimately the wear and tear on this chassis will be minimal. I was in hurry when I did some of the rear suspension work 2 years ago and threw some cheap rattle can primer over the bare metal under the bed. It held up great with no prep.
At this point I will knock the loose stuff off and use some KBS Chassis Coat on it. I will cover that with some satin enamel. Good for another 60+ years.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-01-2016, 10:42 PM   #853
Coach529
Coach529's Avatar
I have a tendency to over analyze the crap out of stuff. I am all stressed about making this chassis look perfect....perfect welds, perfect finish....when In all actuality once it is all assembled it will barely be seen..
1949 Chevy 3600
Old 01-01-2016, 11:00 PM   #854
joedoh
joedoh's Avatar
I called one of those soda blasting guys for a quote on coming out and blasting my frame and the inside of my cab, he wanted $300 plus $300 for the drive! in my opinion he is the one out in BFE, so I declined. but it got me thinking, and researching, and I found that northern tool sells a $70 part to let you use a pressure washer as a dustless blaster. the pressure washer requirements are pretty high so I dont think a $200 washer would work well, but if I compare the $600 one time cost of having someone come out to the ability to use it any time I want... I was ready to buy a washer and the weather went from 50s to 30s, haha. so it may be spring before I try it, but something to think about.
Old 01-01-2016, 11:11 PM   #855
Advanced Design
Advanced Design's Avatar
Interesting...
http://www.northerntool.com/shop/too...duct_8520_8520
Advanced Design is offline   Reply With Quote
Old 01-01-2016, 11:52 PM   #856
solidaxel
solidaxel's Avatar
The only guy who will REALLY like it is the guy who changes the oil & filter!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-02-2016, 12:59 AM   #857
Coach529
Coach529's Avatar
Originally Posted by Advanced Design View Post
That is an interesting set up.....and for the price I may invest in one just to see how it would work with my 2500psi pressure washer.
Unfortunately I do not have the heated area to wash inside.......and the weather outside will not allow it until APRIL.
1949 Chevy 3600
Old 01-02-2016, 01:00 AM   #858
Coach529
Coach529's Avatar
1949 Chevy 3600
Old 01-02-2016, 10:30 PM   #859
Coach529
Coach529's Avatar
Nothing huge accomplished the last couple days. I kind of butchered the relief for the rack and pinion, so I worked last night to close that up neatly. Use some 4" pipe and some 1/8" flat plate. 4" holesaw was also used......damn I need a Plasma Cutter.
I drug the frame outside today and cleaned up all the loose rust and buildup on it. It is almost ready for paint.
Tonight I drug my Thunderbird IRS into the shop and started getting it ready for install.
I will be detailing the IRS install on a separate thread linked below!!
http://67-72chevytrucks.com/vboard/s...d.php?t=666720
1949 Chevy 3600
Old 01-02-2016, 10:38 PM   #860
youngrodder
youngrodder's Avatar
Hardcore working outside in the cold temps. Looks like your frame is getting there. I spent the afternoon welding up more holes in my frame...
Keep at it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-02-2016, 10:50 PM   #861
Coach529
Coach529's Avatar
Keep at it.
Marc
It actually wasn't that bad today......low 30's. I wanted to try and keep the mess out of the garage.
1949 Chevy 3600
Old 01-02-2016, 11:32 PM   #862
Advanced Design
Nice fix on the notch Coach. I agree, outside in the snow is hard core...awesome!
Following along on the irs redo too.
Old 01-02-2016, 11:55 PM   #863
YukonXL04
YukonXL04's Avatar
Your definitely more hard core than me. It's been low 40's and windy here and it was too cold for me to mess with the truck. Good job!
YukonXL04 is offline   Reply With Quote
Old 01-03-2016, 12:22 AM   #864
iowaboynca
iowaboynca's Avatar
C'mon now it was mid to high 40's today in Central CA and I was able to get some work in...but then again the wife did come out and ask me if I was cold and my DA replied, "ugh no. why?" This sure ain't the Iowa I grew up in...
Keep up the good work on the build Coach! i love your truck!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 01-03-2016, 01:41 AM   #865
Coach529
Coach529's Avatar
30's in January is about as good as it gets up here in NoDak.
If it would have hit 40 I would have shut the heat off and opened up all the garage doors!!
1949 Chevy 3600
Old 01-03-2016, 11:29 PM   #866
Coach529
Coach529's Avatar
IRS install sneak peak.....
1949 Chevy 3600
Old 01-04-2016, 12:41 AM   #867
60chevyjim
60chevyjim's Avatar
rustoleum semi gloss works nice for chassis and under hood .. I buy it by the quart .
thin it with acetone to spray it or you can brush it on the chassis .
60chevyjim is offline   Reply With Quote
Old 01-04-2016, 04:27 AM   #868
lower50's
lower50's's Avatar
Nice work on the frame, IRS is going to be sweet!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-04-2016, 01:23 PM   #869
Coach529
Coach529's Avatar
Thanks I am so damn close to setting it down on the ground and checking ride height. Maybe tonight!!
1949 Chevy 3600
Old 01-05-2016, 12:39 AM   #870
BIGglaSS
BIGglaSS's Avatar
Nice. I was going to do a TBird IRS, until I scored a deal on two C4 IRS. Yours looks a lot easier.
BIGglaSS is offline   Reply With Quote
Old 01-07-2016, 10:15 PM   #871
Coach529
Coach529's Avatar
Found this picture on Instagram. I think Henry needs blue wheels.
What do you think?
1949 Chevy 3600
Old 01-07-2016, 11:41 PM   #872
99 to Life
99 to Life's Avatar
I could go either way, blue or black. I like a lot of white with blue trucks, so like a cream with wide whites or something light would look cool too. lotta options with your blue.
Old 01-07-2016, 11:42 PM   #873
Coach529
Coach529's Avatar
I always thought a cream would look good......but I was afraid it would blend into the wide whites too much......
1949 Chevy 3600
Old 01-07-2016, 11:50 PM   #874
99 to Life
99 to Life's Avatar
put a center cap on and a beauty rim, break it up a tad, or just go darker cream. either way I think it would look good.
Old 01-07-2016, 11:53 PM   #875
Coach529
Coach529's Avatar
I contacted Cragar about a beauty ring......they do not make one, but they say a thin one will fit. I need to round up a set.
1949 Chevy 3600
