Old 01-02-2016, 11:20 PM   #1
hayhauler71
hayhauler71's Avatar
285 70 15 BF Goodrich silvertown tires
Looking to upgrade to a taller rear tire. Any one running this size tire that can throw up a pic and tell me there back spacing on there wheel. Thanks in advance.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-03-2016, 12:08 AM   #2
uncle
Re: 285 70 15 BF Goodrich silvertown tires
Any 8 or 8.5 standard offset wheel would work. I also had 10" with narrow housing and same tires with 7" drop on both trucks.
uncle is offline   Reply With Quote
Old 01-03-2016, 12:16 AM   #3
uncle
8.5 wheel with stock 5 lug rear.
Old 01-03-2016, 12:18 AM   #4
uncle
10" with 67-69 housing and standard offset
Old 01-03-2016, 02:33 AM   #5
CG
BlahBlahBlah
Mind giving the specs on the orange truck ... tire and wheel size front and rear. Also what drop do you have and how did you do it?
Excellent proportions on that ride. Id like to stick the picture with the info in my 67-72 truck folder ... thanks!
Old 01-03-2016, 09:31 AM   #6
uncle
Orange truck at the time had 8.5 wheels on all 4 corners, but now has 7" on front(tires hit inner fender). Front drop is ece 2.5 spindle/2" spring. Rear is ece 6" spring/1" block. Can't really tell by looking with 7" on front but lot safer driving. 285/70/15 rear tire. 235/70/15 front tire. Wheels are American torque thrust d.
Old 01-03-2016, 10:53 AM   #7
The best look for these trucks!
Old 01-03-2016, 11:13 AM   #8
BugzC10
BugzC10's Avatar
275/60R15 on 15x8 w/ 3.8" BS rear wheel.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-03-2016, 11:31 AM   #9
CG
BlahBlahBlah
Amen Brother! The blue step side looks great too. I would actually love to have a short step side box and fenders if one locally ever pops up. Right now we are starting to collect parts for several trucks. Several of my friends and family have decided they want to put together some 67-72 trucks (that's why Im getting all the parts lately).
Old 01-03-2016, 11:36 AM   #10
CG
BlahBlahBlah
Can you give the exact specs on this truck front rear ... tire and wheel size, front and rear drops too please?
Old 01-03-2016, 12:33 PM   #11
BugzC10
BugzC10's Avatar
Drop: 4.5" front (CCP 2.5 spindles + CCP 2" drop springs), 5.75" rear (CCP 4" drop springs + 1.75" block/plate)
Wheels: TTII 15x8 w/3.8BS rear, 15x7 w/3.78BS front.
Tires: BFG 275/60R15 Rear, BFG 235/70R15 Front (Both 28" tall)
I went with 275/60 in rear because 295/50 are not readily available. Went with 235/70 in the front to give me additional LCA ground clearance.
Old 01-08-2016, 11:16 AM   #12
hayhauler71
ttt
Fuzzy
Old 01-27-2016, 04:50 PM   #13
hayhauler71
They are on now and fit great. 285 70 15 rear 255 70 15 front
Fuzzy
Old 01-27-2016, 07:26 PM   #14
junksaver
Looks good. I like that size tire.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 01-28-2016, 02:31 AM   #15
dell72
I don't have any pictures to share, but my 69 SWB stepside has 285/70/15 rear and 235/70/15 front. tires are mounted on stock 73-87 style 6 lug G.M. wheels with dog dish hubcaps. front suspension has 1.5 coils cut off the stock springs. rear has 6" drop springs with a 1" lowering block.
dell72 is offline   Reply With Quote
Old 01-28-2016, 07:12 AM   #16
Your truck is lowered 1.5/7? Do you have a way to show pictures?
Old 01-28-2016, 02:23 PM   #17
dell72
My truck is lowered approximately 5" in the front. This was accomplished by cutting 1.5 coils off the stock front coil springs.
Old 01-28-2016, 02:44 PM   #18
SIXTY9
Do the Silvertown treads match the BFGoodrich pattern?
SIXTY9 is offline   Reply With Quote
Old 01-28-2016, 04:16 PM   #19
hayhauler71
Not the same but close
Fuzzy
Old 01-28-2016, 08:57 PM   #20
Sorry, read that wrong, as 1.5" not 1.5 coils... Gotcha!
Old 01-28-2016, 09:05 PM   #21
Average Joe
Average Joe's Avatar
Where are you guys buying these 285's? I have seen them on Cokers web site, are they the only distributor?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 01-29-2016, 02:19 AM   #22
dell72
summit racing sells them
