Southern Nevada Coal Roller
Is there a small to big window conversion?
I am looking at a custom crew cab build for sale and they have a small window built in. I prefer the large rear window and I can't just switch cabs.
Any options on this with out a lot of work? Chris
Chris 72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo. 36 Chevy P/U rat rod project. 4bta cummins ![]() |
Re: Is there a small to big window conversion?
Find a cab with a big back window, cut it out and then patch it into your truck.
I would guess you would need to make an oversized rectangular template that is about 2" larger than the big window and use that as a template for both trucks. They make panel clamps to make the job easier than just using a magnet to hold the panels in alignment. The welding without a lot of distortion is going to be the hardest part.
Terry Soon to be retired and moving to Bristol, TN. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Interesting question. While you wait for the answer, lemme just say this: the small window is just rare enough to make it appealing to me. Only came on some 1967 trucks. If it were mine, I would leave it. But it's not mine, so.... good luck! I hope you find the answer you're looking for.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#4 | |
the boat guy
Cut and weld is the only option. There's plenty of scrap cabs to choose from.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
its a 4 bolt swap
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
There is a CL listing in south new jersey for a GM NOS entire rear cab section ,
I never even knew they were produced ,but apparently they were and this guy has one. |
#7 | |
20' Daredevil (Ret)
![]() After so many years of driving trucks with outside mirrors only, I don't look through the rear glass very often. In fact I removed my '72's inside mirror because 1) oncoming headlights at night appear as rapidly overtaking traffic from behind, and 2) I wasn't using that mirror anyway.
Texas Big Wig
I did the reverse of what you're wanting on my 88 GMC, if you click the link in my sig labeled "driver" you may get some idea of what you'd be getting into
I'm with others, as much as I love the small back window of the 67, in a crew cab it would be a pain to see out of and I would rather have a large back window... Can't say that I would cut out a small window to change it tho |
I figure all that work was done to build that cab, I'd leave it be and keep looking. Custom-built crew cabs aren't everywhere but, chances are, any you find will have a big back window. Let someone who appreciates the small window have this one. I'd sooner build another crew cab than redo that one.
