Old 01-02-2016, 07:30 PM   #901
99 to Life
99 to Life's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
I'm liking the progress. nice job on the hinges. those things are noooot cheap if you buy repros, so fixing them is def worth it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-02-2016, 07:59 PM   #902
Advanced Design
Advanced Design's Avatar
Originally Posted by blake's first View Post
Just a quick question On the AD trucks are the cabs the same on a pickup as a one tone truck
Blake, yes the cabs are the same.
Advanced Design is offline   Reply With Quote
Old 01-02-2016, 08:02 PM   #903
Advanced Design
Thanks 99. Didn't need the bushings amazingly enough. The pins were siezed up though and I guess the doors didn't get much use. They were probably never lubed.
Old 01-03-2016, 10:54 AM   #904
oldman3
oldman3's Avatar
Originally Posted by Advanced Design View Post
Hey Jim, Happy New Year to you guys too! Did you notice I am using your flanged nut idea? LOL!
Doug, I always just used regular nut, Mark came up with the flanged nut, more area to weld.
The bag of 100 are called Tee Nuts, used in wood alot. I used them in many builds, also more to weld too. I've used them up to 3/8", not sure if they make them in larger sizes...Jim
oldman3 is offline   Reply With Quote
Old 01-03-2016, 11:12 AM   #905
Advanced Design
Thank you Jim. I was drawing a blank on the name for tee nuts. Fastenal has them up to 3/8". Those would be handy in a number of applications.
Sorry Mark, I was giving Jim credit for the flanged nut idea. Works really well!
One of the benefits of spending time here is learning from each other.
Here is a link to tee nuts.
https://www.fastenal.com/products/de...ee%20Nuts%22|~
Old 01-04-2016, 10:14 AM   #906
reaper71
reaper71's Avatar
No worries my friend!!
Things like this get passed down from generation to generation AKA Hot Rodding
Mark...
reaper71 is offline   Reply With Quote
Old 01-05-2016, 12:43 AM   #907
lower50's
lower50's's Avatar
Nice work AD. I like your tank and compressor location. What kind of lines are you running?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-05-2016, 04:23 AM   #908
Advanced Design
Thanks Lower, nothing trick on the lines. Just using the dot stuff that came from Ridetech is my plan. Except for the final run to the front bags, where I have a steel braided set up to make use of. And I am always open for suggestions.
Old 01-09-2016, 06:10 PM   #909
Advanced Design
Mark...
For sure Mark. I have certainly picked up a lot of good ideas on here!
Hey Marc, here is the crossmember I mentioned in the PM. I took it out for fuel tank clearance.
Old 01-09-2016, 06:20 PM   #910
Advanced Design
Then I threw the body back on the frame to measure for a fuel tank. This one was a custom piece that was in the 56 Chevy when it had the irs and is 4 inches shorter. I think the unit from Tanks will work really well, if it will fit. There is room between the frame and body for the fill to go through the lower body behind the left tire, then turn up and exit through the fender. A friend has one for his current 52 Buick build so I will probably borrow it for test fitting before buying one.
I was also pretty happy with the fit of the tanks and pumps, not so happy with the battery box location. It clears the body well, though with the running boards on I don't know that I can service the battery. Ha on me....restoration guys are pointing and laughing.
Old 01-09-2016, 06:28 PM   #911
Advanced Design
Moving to the other end of the vehicle in figuring out what fits, a friend found this ac compressor mount at Vintage Air. Looks like it will provide clearance to the right inner fender and works with the truck accessory drive. It might interfere with a thermostat housing that points straight forward.
http://www.vintageair.com/2015%20Cat...talog%2068.pdf
Old 01-09-2016, 06:34 PM   #912
Advanced Design
And if the 56 tank won't work....it might be too long front to back....the 53 / 54 tank from Tanks is a possibility. Especially if the filler neck connection unbolts like it shows in the picture.
Wouldn't it be great to have all these parts on a shelf so you could just grab one and test fit, instead of guessing based on measurements and pictures?
Old 01-10-2016, 12:01 AM   #913
youngrodder
youngrodder's Avatar
So did you confirm that that brace you removed was not used as for the rear body mounts? Again, I could be wrong.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-10-2016, 11:27 AM   #914
Advanced Design
Marc
I don't think it was on this Burb Marc. I didn't remember removing any body bolts in this area. To confirm, I checked out the original floor and crossmember. There are no witness marks showing a mount.
Old 01-10-2016, 01:28 PM   #915
youngrodder
Thanks Doug. Sorry to put you through the trouble. You beat me to it. I was going to go out to the garage and look at my stock floor to confirm.
Marc
Old 01-10-2016, 01:50 PM   #916
Advanced Design
No problem Marc. I looked yesterday before I took the crossmember out. Glad you mentioned it just in case I needed it.
Another option for the fuel tank is this one for a 65 Burb a friend is building. Going to test fit it in addition to a couple of others. And will evaluate the 69 Mustang with this type of fill too.
Old 01-10-2016, 11:09 PM   #917
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
I have this one! The compressor clears, but the tensioner *just* hits the inner fender - I am planning to make a vertical cut in the inner fender and bow it outward ~3/8" to make a pocket and gain the clearance I need.
I suspect, since your engine is about 1" further back than mine, you should be good to go without modifications
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 01-10-2016, 11:18 PM   #918
Advanced Design
Thanks JJ! Good to know.
I just came across another fuel tank option dwcsr linked us to on one of his builds. Didn't remember this one. 68 Camaro tank. Looks like a good option.
Old 01-11-2016, 09:42 PM   #919
65sub
65sub's Avatar
Hi A.D. I 've been searching for a tank for my truck too. Lots of options available but I couldn't find any that worked for me so I decided to build my own. I bought a sheet of stainless steel and then all the hardware from Tanks Inc. Probably a more expensive route but it will fit. If you find a tank that fits you could move the fill location with parts from Tanks Inc.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-11-2016, 10:05 PM   #920
Advanced Design
Thanks 65sub. I was just over on Tanks website tonight looking at dimensions and parts needed. The 68 Camaro fuel injection tank is a good possible solution, if it doesn't hang down too low to do the side fill I have in mind.
Hope you post up your tank build as I would like to follow that!
Old 01-24-2016, 11:25 AM   #921
Advanced Design
Well, after lots of measuring, thinking and research I am 99% sure of going with the 68 Camaro fuel injection Tank from Tanks.
Next I wanted to make sure the rear fenders and running boards would fit again with this new chassis. Before I mounted the rear fender I still had 6 or 7 Reaper71 inspired flanged nuts to locate, drill for and install.
Another thing I learned on here was to turn the wire speed up on overhead welding from a comment one of the guys mentioned somewhere. I did and what a difference in the weld quality.
Anyway, the wheel centers nicely.... yeah, ugly shop rollers.
Old 01-24-2016, 11:31 AM   #922
Advanced Design
Install the running boards....I learned there was a difference on my brackets and the left front one was at an angle pointing forward that didn't want to match up with the running board. Hmmm...right front is the same so I swapped them side to side. That worked.
Anyway, mounting the running boards to see if the truck really needs the rear bracket. The 4 link arms mount to the outside of the frame right where the bracket went.
And before I mount the left board I rediscovered the center mount on the left board was trashed.
Old 01-24-2016, 11:37 AM   #923
Advanced Design
The swag press brake was really handy for this. Using 16 gauge steel I ended up fabricating one from 3 pieces, left side, top and right side. The piece was too narrow for the press brake to make it from one piece.
Old saw horses and 2x boards sure make a handy cutting bench.
Old 01-24-2016, 11:41 AM   #924
Advanced Design
Drilled holes and slotted to use the square shank mounting bolts. Of course I did a lot of in place fitting before drilling and plug welding in place.
This took most of two Saturdays as we've been spending a lot of time with the Grandsons coming over. Prayers answered and God is good!
Old 01-24-2016, 12:00 PM   #925
FarmerSid
FarmerSid's Avatar
Nice fab work Doug! I will have to do the same with a couple running board mounts too.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
