Old 01-05-2016, 10:13 AM   #1
scottv
Can I add gauges to this cluster dash?
There is a large top middle spot "empty" (I would like to add a tach there-can I just add a used GM tach here?), and a bottom right next to steering column spot also empty. I have an aftermarket (AEM) wideband guage-can I put that in this spot if it's the right size? I didn't know how easy it is to add non-GM gauges to these clusters. Or do I have to replace the whole cluster? Thanks!
scottv is offline   Reply With Quote
Old 01-05-2016, 10:48 AM   #2
DBK81
DBK81's Avatar
Re: Can I add gauges to this cluster dash?
I have seen a Tach added to the large centre hole, there is actually a thread on this on the first page of this board right now. Not sure on the other smaller holes.
DBK81 is offline   Reply With Quote
Old 01-05-2016, 10:54 AM   #3
jjzepplin
jjzepplin's Avatar
It is hard to put in non factory gauges without making your dash look like a hack job. Stock gauges are nice looking though. Kinda pricey- You can look around on here and find factory tach dashes and some came with either vacuum or air pressure gauges in the lower spot. Usually came in larger industrial trucks but will work in ours. You can also find 80lb oil gauges as well. I have one I am building with factory tach and 80lb oil as well as vacuum. To buy it would be over 500 bucks. I built mine for only $550. Yeah I know- that's how it goes here. If you want a $50,000 truck you have to spend $100,000.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-05-2016, 11:03 AM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: Can I add gauges to this cluster dash?
check out this Camaro tach mod that "Gringoloco" did...
http://67-72chevytrucks.com/vboard/s...d.php?t=251017
plenty of Camaro parts in the bone yards or Craigslist....easy to do and cheap!
Ben
snipescastle2 is offline   Reply With Quote
Old 01-05-2016, 11:15 AM   #5
Cajun
This is how my dash will look when I get all the gauges in. As far the middle hole, I am still trying to figure out what to put in there. I would like to do a clock but for that size is about $130 to somewhat match the white face gauges. I will have a speedo, tach, water, oil, volt and gas gauges.
Cajun is offline   Reply With Quote
Old 01-05-2016, 12:13 PM   #6
mgore68
mgore68's Avatar
Cajun, what size and brand speedo is that you used? I have an eqqus tach in mine that I believe was 3 1/4". It did not fit perfectly but comes with a rubber gasket you can use to lock it in the hole like you install a windshiels with a rope and it works perfect. The eqqus 2" gauges fit perfectly in the small holes and come with a screw on ring that work just right on the back.
mgore68 is offline   Reply With Quote
Old 01-05-2016, 12:24 PM   #7
Cajun
I believe the tach and speedo are 5". Now the factory holes are a little smaller, but I will either use some type of rubber gasket or weatherstripping material to keep them snug or just make a quick mount to the back. The Equus gauges fit perfectly as you said with the screw on ring on the back.
